AVATOR BOX (China Phones Service Tool) |
07-30-2014, 10:23 | #1 (permalink) |
No Life Poster Join Date: Apr 2007 Location: Edge of the world
Member: 492380 Status: Offline Thanks Meter: 184 | [Help] No more authorisation logs [solved ] Please help. trying to authorise box and got error No more authorisation logs. box s/n: 10027123 country: Indonesia email: [email protected] thanks before. |
07-30-2014, 10:57 | #2 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: THE MOBILE SHOP
Member: 1432329 Status: Offline Sonork: 100.1615863 Thanks Meter: 1,626 | Quote:
Request to check S/N (10027123)... (1) You can use AvatorBox Version up to 5.XXX If you want to use latest AvatorBox updates: 1. Buy AvatorBox Activation Code from Reseller 2. Buy AvatorBox Smart-Card from Reseller 3. Register box with AvatorBox Activation Code and Smart-Card - You can order Activation Code from IOS (Infinity Online Service) - You can order Activation Code from Infinity Resellers - You can order Activation Code from Avator Resellers | |
07-30-2014, 11:35 | #3 (permalink) | |
Member: 492380 Status: Offline Thanks Meter: 184 | Quote:
FYI: 1. My box already registered. 2. I already have avator smart card. 3. i can use avatorbox v7.126 (latest version) The cause of the problem is because avator software v7.126 not support COM connection, only USB. So i try use software v6.773 wich is support connect phone via Com port. the sotware v6.733 still asking me to authorize box, even i already copy the "mtauth.dat" to the soft "data" folder. when i try using v7.126 again, the soft asking to authorize software again, and when i try to authorize, i got that "no more authorisation logs" problem. So to avator team please solve my problem, and prease fix the COM port connect in your next update, because not all phone use common USB connector, and i don't have that kind of USB data cable. I only have the MiniUSB & MicroUSB data cable. BR. | |
07-30-2014, 12:29 | #4 (permalink) | |
You should contact to Avator support directly: http://forum.gsmhosting.com/vbb/member.php?u=1427447 | |
07-31-2014, 01:59 | #5 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Quote:
solved soon as br: ernie78 | |
The Following User Says Thank You to ernie78™ For This Useful Post: |
07-31-2014, 05:42 | #6 (permalink) | |
enjoy using avatorbox br: ernie78 | |
