AVATOR BOX (China Phones Service Tool) |
05-08-2013, 23:00 | #1 (permalink) |
No Life Poster Join Date: Nov 2009 Location: portugal Age: 46
Member: 1166261 Status: Offline Sonork: 100.1623881 Thanks Meter: 266 | Huawey g7300..read flash....flash and fix imei done Action=WriteFlash FlashType=Nand boot=Ver5.1232 Expert Mode=Disable Range[start]=0x0 Range[size]=0x08400000 Interface=COM FlashFile=C:\Documents and Settings\carlos32\Ambiente de trabalho\HUAWEY G7300 Comport=COM17 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=00EC00B100000055 NAND_Size=128MB NAND_Name=[SAMSUNG] K9F1G16Q0M Initializing... DA_LIB_VER_5.1.4.3 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00EC00B100000055 Read Hardware Information is done. Get Project ID from phone... Project ID: U5.6PY01V01.05 Changing baudrate to 921600... Done. Extracting Files from full FlashFile, please wait... Boot Info: MTK_BLOADER_INFO_v02 Boot Ver: BYD36_10A_BOOTLOADER_V005_MT6236_U5_6PY01V01_05.bi n Identifier: MTK_ROMINFO_v07 Platform ID: BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_05.BIN Project ID: U5.6PY01V01.05 ExtEMI_InROM found. Analysis the file, Some file may need a long time... The file has not been encrypted. Wait for DRAM detection ... Auto set EMI... External Memory Interface is done. Ext_RAM_size=0x04000000 Downloading Flash file... -------------------Created: 08-05-2013 21:49:36------------------- Chip=MTK Action=WriteFlash FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x08400000 Interface=COM FlashFile=C:\Documents and Settings\carlos32\Ambiente de trabalho\HUAWEY G7300 Comport=COM17 Baudrate=921600 CPU_Type=MT6236 CPU_ID=00000000 NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=00EC00B100000055 NAND_Size=128MB NAND_Name=[SAMSUNG] K9F1G16Q0M Initializing... DA_LIB_VER_5.1.4.3 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00EC00B100000055 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: U5.6PY01V01.05 Changing baudrate to 921600... Done. Extracting Files from full FlashFile, please wait... Boot Info: MTK_BLOADER_INFO_v02 Boot Ver: BYD36_10A_BOOTLOADER_V005_MT6236_U5_6PY01V01_05.bi n Identifier: MTK_ROMINFO_v07 Platform ID: BYD36_10A_PCB01_GPRS_MT6236_S00.U5_6PY01V01_05.BIN Project ID: U5.6PY01V01.05 ExtEMI_InROM found. Analysis the file, Some file may need a long time... The file has not been encrypted. Wait for DRAM detection ... Auto set EMI... External Memory Interface is done. Ext_RAM_size=0x04000000 Downloading Flash file... Waiting for DA to program the Image1... Image1 is done. Downloading Bootloader... Program the 1st block is done. Waiting for DA to program the Image2... Image2 is done. Waiting for DA to program the Image3... Image3 is done. Waiting for DA to program the Image4... Image4 is done. All done. +++++++++++++++++++End at: 08-05-2013 21:58:10+++++++++++++++++++ -------------------Created: 08-05-2013 22:14:46------------------- Chip=MTK Action=IMEI FlashType=Nand boot=Ver5.1152 Expert Mode=Disable Range[start]=0x0 Range[size]=0x08400000 Interface=COM FlashFile=C:\Documents and Settings\carlos32\Ambiente de trabalho\HUAWEY G7300 Comport=COM17 Baudrate=921600 Initializing... DA_LIB_VER_5.1.4.3 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=2 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6236, HardwareVer:8A02, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... Lid=0x1_0x0088, Val=FFFFFFFFFFFFFF0F0000 Lid=0x1_0x00C6, Val=00000000000000000000 Lid=0x1_0x0182, Val=FFFFFFFFFFFFFFFFFFFF All done BR |
The Following User Says Thank You to carlos32 For This Useful Post: |
05-09-2013, 12:55 | #3 (permalink) |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Thanks for TestReport and upload Flashfile. Regard AvatorBox Team FullFlashPak |
The Following User Says Thank You to FullFlashPak For This Useful Post: |
05-12-2013, 04:52 | #4 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Skype , Sonork
Member: 649528 Status: Offline Sonork: 100.1590443 Thanks Meter: 6,958 | Hi Thanks for the result Suggestion : please post screen shot as well if possible Regards AVatorbox Team |
The Following User Says Thank You to GsmUniversal For This Useful Post: |
