AVATOR BOX (China Phones Service Tool) |
02-22-2013, 07:38 | #3 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | Yes, because the phone lock code - can be deducted. I'm interested engineering codes: Entry code in the engineering menu! And other engineering codes that previously could read here: i9300 CPU: SC6530 how to read the master code??? Last edited by Kolumb; 02-22-2013 at 07:44. |
02-22-2013, 07:55 | #5 (permalink) | |
Member: 1558427 Status: Offline Thanks Meter: 630 | Quote:
I get paid to do, so I read engineering codes. Question - i9300 CPU: SC6530 how to read the master code????!! Maybe in a hex editor? | |
02-22-2013, 08:00 | #6 (permalink) | |
Someone on the case can answer?!! | |
02-22-2013, 08:04 | #8 (permalink) |
Freak Poster Join Date: May 2010 Location: valchican republic
Member: 1295748 Status: Offline Thanks Meter: 86 | yes much helpful if avator box team add read codes to newest SPD chips in near update. i also have one set here i9300 CPU: SC6530 i formatted many times privacy code won't remove, |
02-23-2013, 10:40 | #10 (permalink) |
Member: 1558427 Status: Offline Thanks Meter: 630 | Solved! Thanks program ChinaResMan p.s. Log AVATOR BOX: Code: Connecting... Spd USB-to-Serial=COM18 Connected...sending boot... FDL test...OK ArmBootMode: 6530000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6530 Flash: SF_MX25U6435E setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 94 IMEI 1=352273017386340 ------Auto Format Address------- Start=0x007B0000 Size =0x00050000 Read FS info...done Last edited by Kolumb; 02-23-2013 at 10:47. |
