AVATOR BOX (China Phones Service Tool) |
07-20-2013, 14:58 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 594996 Status: Offline Thanks Meter: 12 | I9300 spd 6820 dead after flash saved firmware unlock function not solve its problem, i save firmvare phone and find analog phone save firmware, flash phone which google - phone not start, i flash he first firmware but not luck, phone àlso not included. What i can doing now? |
07-20-2013, 15:30 | #2 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | Hello bro, we need screen shots of your total work by avatorbox. Regards amn32 |
The Following User Says Thank You to amn32 For This Useful Post: |
07-20-2013, 18:03 | #3 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | Quote:
Please post ScreenShot and Log of Operations!! Is Necesary for solve you problem!! Thanks in Advanced | |
The Following User Says Thank You to resident2011 For This Useful Post: |
07-20-2013, 20:25 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: hall road pakistan
Member: 782530 Status: Offline Thanks Meter: 8,136 | Quote:
brother please post here screen short or logs. Sure we are help you. Maybe we have same firmware. Br | |
07-21-2013, 05:51 | #5 (permalink) |
Member: 594996 Status: Offline Thanks Meter: 12 | here is log save firmware phone which google account: Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=6820 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=i9300_tv Comport=COM4 Baudrate=921600 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=009800BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_TYBC0A111236KC10 Initializing... DA_LIB_VER_5.6.1.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM26 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_TYBC0A111236KC10 setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: i9300_tv.cmz All Done. __________________________________________________ ____________________ Here is save firmware normal phone log: Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Documents and Settings\Admin\Рабочий стол\i9300_TV Comport=COM4 Baudrate=460800 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=009800BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_TYBC0A111236KC10 Initializing... DA_LIB_VER_5.6.1.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM26 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 460800 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 460800 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_TYBC0A111236KC10 setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: C:\Documents and Settings\Admin\Рабочий стол\i9300_TV.cmz All Done. __________________________________________________ _____________ here is write phone whic google firmware normal phone: Chip=SpreadTrum Action=WriteFlash FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x21002000 Interface=USB FlashFile=C:\Documents and Settings\Admin\Рабочий стол\i9300_TV.cmz Comport=COM4 Baudrate=921600 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=009800BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_TYBC0A111236KC10 Initializing... DA_LIB_VER_5.6.1.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM26 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_TYBC0A111236KC10 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Erasing Flash... Done. Programming... All Done. here phone dont start _________ __________________________________________________ _______ here is write hi native firmware log: Chip=SpreadTrum Action=WriteFlash FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x21002000 Interface=USB FlashFile=D:\program\avator\i9300_tv.cmz Comport=COM4 Baudrate=921600 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=009800BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_TYBC0A111236KC10 Initializing... DA_LIB_VER_5.6.1.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM6 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_TYBC0A111236KC10 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Erasing Flash... Done. Programming... All Done. after also not power on |
07-21-2013, 08:04 | #7 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | This incident was repeated with the phones on this chip memory NAND_TYBC0A111236KC10 http://forum.gsmhosting.com/vbb/9582847-post3.html Please support, pay attention to it. |
The Following 2 Users Say Thank You to Kolumb For This Useful Post: |
07-21-2013, 15:13 | #9 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote: thanks for your file . we will investigate about this problem | |
The Following 3 Users Say Thank You to Smart-gsm For This Useful Post: |
