Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 01-23-2012, 09:48   #1 (permalink)
MOHIT_THAREJA's Avatar
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
kfive k598+ flashing error { solved }
when i write flash file show this error
Initializing...
DA_LIB_VER_3.9.0.0
It is sensing the pinout fast...
RXD=3 TXD=8
Connecting...
Connected...sending boot...
FDL test...OK
ArmBootMode: 6600700900026A00_01
Wait for init Commzero Security Engine...
Done.
Loading bootloader...
Done.
Changing baudrate...
Set baudrate to 115200 is ok
Reading phone HW info...
Read info is done.
CPU: SC6600L7 Flash: NOR_ST_M30L0T7000T0
setting the Flash Parameters...
Settings have been completed!
Unlocking all blocks before program/erase...
Buffer Program: Enable
Unlock Done.
Programming...
Compare Image: Enable
Error: Failed to read ACK.
Old 01-23-2012, 10:00   #2 (permalink)
FullFlashPak's Avatar
Member: 782530
Thanks Meter: 8,127
rehot flash ic and chack again your problem will be solved.
AvatorBox Team
Old 01-23-2012, 10:19   #3 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
AvatorBox Team
before flash set is on perfect only calling problem then when i reset set hang on logo then i arrange flash file when i write show this error then now set is dead
Old 01-24-2012, 01:49   #4 (permalink)
ernie78's Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,712
check cable chip or use manual pinout then flash again
post result
Old 01-24-2012, 08:01   #5 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
post result
bro i already use rx tx because charging connector is damaged before flash set is on then when i flash show error then set id dead how to recover pcb is fresh
Old 01-24-2012, 09:21   #6 (permalink)
ernie78's Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,712
what is fone problem first??
flash your readflash backup or flash via tested firmware
post result
Old 01-24-2012, 16:26   #7 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
post result
my set problem is hang on calling
i have tested file check my first post when i flash show this error Error: Failed to read ACK.
Old 02-29-2012, 09:59   #8 (permalink)
parth gupta's Avatar
Member: 942210
Sonork: 1511
Thanks Meter: 75
ineed kfive k598+ flash file
Old 02-29-2012, 14:31   #9 (permalink)
Member: 1502539
Thanks Meter: 41
memonarif
brother i have same model phone but phone workin ok but no red flash file brow see this see this error hoe to red and ired flash sand to this file
Old 02-29-2012, 15:29   #10 (permalink)
Member: 782530
Thanks Meter: 8,127
hello
post in right section
and send phone logs or screen short with avatorbox
phonre problem
AvatorBox Team
Old 03-01-2012, 08:19   #11 (permalink)
Member: 1143809
Sonork: 100.1602432
Thanks Meter: 574
here is your file
Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 20:37
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 16:57
Page generated in 0.42991 seconds with 8 queries
