AVATOR BOX (China Phones Service Tool) |
08-25-2013, 20:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: Ukraine Khmelnytsky
Member: 1558427 Status: Offline Thanks Meter: 630 | N9300mini CPU: SC8810 Flash: NAND_H8BCS0UN0MCR Read/Write DONE [test report] N9300mini CPU: SC8810 Flash: NAND_H8BCS0UN0MCR Read/Write DONE [test report] ReadFlash Code: Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=6820 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=D:\damp spread avator\N9300mini\N9300mini Comport=COM10 Baudrate=921600 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_5.6.1.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: D:\damp spread avator\N9300mini\N9300mini.cmz All Done. WriteFlash Code: Chip=SpreadTrum Action=WriteFlash FlashType=Nand boot=6820 Expert Mode=Disable Range[start]=0x0 Range[size]=0x21002000 Interface=USB FlashFile=D:\damp spread avator\N9300mini\N9300mini.cmz Comport=COM10 Baudrate=921600 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_5.6.1.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM11 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Erasing Flash... Done. Programming... All Done. |
The Following 2 Users Say Thank You to Kolumb For This Useful Post: |
08-26-2013, 07:08 | #2 (permalink) |
Member: 1558427 Status: Offline Thanks Meter: 630 | DOWNLOAD FULL ______________________________ |
