Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 07-14-2013, 14:34   #1 (permalink)
rajendrakumar's Avatar
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
need help
hello sir, i have spd 6820 cpu phone.i try to read flash the phone with avator latest, but the mobile did not connect , is any special cable need for boot ??
Old 07-14-2013, 14:48   #2 (permalink)
Member: 1427447
Sonork: 100.1596998
Thanks Meter: 4,218
Do these steps
1. SPD TAB
2. Select Read info or read Flash
3. Seelct Boot nand
4. Select boot 6820 or 8810
5.Select USB
6. uncheck pinfind
7. Press Start
Than Connect usb boot cable to phone And Put Battery within 2 or 3 seconds . software will detects
if you dont have usb boot cable . , Connect normal usb with hold Boot key and insert battery
in your device manger , port must be detect like this
Example :-
Old 07-14-2013, 16:26   #3 (permalink)
FullFlashPak's Avatar
Member: 782530
Thanks Meter: 8,136
hi brother
if your understand avatorbox mathed . then very good.
if cant understand conect me sonork i solved your problem.
Regard
FullFlashPak
Old 10-23-2013, 14:41   #4 (permalink)
Member: 488940
Sonork: 100.1594730
Thanks Meter: 110
problem solved, i read working phone flash file then i write to the problem phone.now phone become alive.thanks to avator team.
Page generated in 0.12591 seconds with 8 queries
