AVATOR BOX (China Phones Service Tool) |
04-16-2015, 18:34 | #1 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Tajikistan / Russia-Siberia Age: 30
Member: 1977205 Status: Offline Thanks Meter: 13 | Need help Micromax Bolt A28 spd8810 dead [ solved ]! [IMG] upload[/IMG] |
04-16-2015, 19:12 | #2 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
Pls Post Screenshot of Flashing Logs Br. Puneet5154-AvatorBox HelpDesk | |
The Following User Says Thank You to PUNEET5154 For This Useful Post: |
04-16-2015, 19:52 | #3 (permalink) |
Member: 1977205 Status: Offline Thanks Meter: 13 | Bro I forgot to make a screenshot . Now phone not detect in device manager. If you need I will make readinfo screenshot of second working phone . |
04-17-2015, 09:54 | #6 (permalink) |
No Life Poster Join Date: Dec 2010 Location: Gsm Hosting (INDIA)
Member: 1478271 Status: Offline Sonork: 100.1608386 Thanks Meter: 1,806 | can you post here with back sticker screen shot we ,ll try to help again alive your set also need your Flashing Log Check in avator box software Folder CMZ.text |
04-17-2015, 10:37 | #7 (permalink) | |
Member: 1977205 Status: Offline Thanks Meter: 13 | Quote:
Here is Flashing log : Code: Chip=SpreadTrum Action=WriteFlash FlashType=Nand boot=8810 Expert Mode=Disable Range[start]=0x0 Range[size]=0x21002000 Interface=USB FlashFile=D:\jakhongir\firmwares\China\MicromaxA28_spd8811.cmz Comport=COM6 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00EC00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_K9K4G16Q0M Initializing... DA_LIB_VER_6.2.0.1 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Connected...sending boot... Spd USB-to-Serial=COM94 Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_K9K4G16Q0M setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Erasing Flash... Done. Programming... All Done. фото хостинг[/IMG] | |
04-17-2015, 11:48 | #8 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Under Blue
Member: 569925 Status: Offline Sonork: 100.1624057 Thanks Meter: 6,313 | CPU: 88100001 Flash: NAND_K9K4G16Q0M some times create problems .Click on link bellow and get file ,write it with other free tool. https://doc-08-68-docs.googleusercon...OGs?e=download |
04-17-2015, 16:46 | #9 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Quote:
1-Remove battery ,connect usb cable to phone but not to computer 2-Press start button of avatorbox 3-Now keep press boot key ,may be vol down key of phone. 4-Now connect cable to computer 5- Insert battery to phone Sure phone will be detected or you can use auto boot modified cable for all process. | |
04-18-2015, 08:40 | #10 (permalink) | |
unforunatly Avator box couldn't solve my problem even readed firmware from 100% working file , but the sets are the same and flash Id also. I am disappointed. | |
