AVATOR BOX (China Phones Service Tool) |
04-06-2019, 09:13 | #1 (permalink) |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | oppo f3 not supported with avator pro Code: Operation : Read Info Brand: OPPO Model: MTK_AUTO Error Report: OFF Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek USB Port_V1632 (COM37) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6755 [MT6755], SW: 0001, HW: CB00 BL Ver: FE; Indicate: 00000005 User DA Ver: MTK_AllInOne_DA_v3.3001.00.00 Verifying auth...ok Loading boot... INT_SYSRAM_BOOT test completed. Any errors manually select "ConnectMothods" and try again Connection type: Error: config command failed Error: config command failed2 Error: config command failed Error: config command failed Error: config command failed Error: config command failed2 Error: config command failed Error: failed to read state Error: failed to read state Operation Done: 00:00:19 Avator Pro SW 2.4 |
04-06-2019, 09:39 | #2 (permalink) |
Member: 2636476 Status: Offline Thanks Meter: 61 | thnx kamal singla sir for help me Code: Operation : ScreenLock Unlock/Relock Brand: OPPO Model: MTK_AUTO Error Report: OFF Hint:Power off phone, Insert usb cable (Connecting 'BROM Mode' Hold Bootkeys) scanning usb device... Phone found: MediaTek USB Port_V1632 (COM90) A thread is created to handle new usb connection, pls wait... Any errors please select another boot and try again. SoC: 6755 [MT6755], SW: 0001, HW: CB00 BL Ver: FE; Indicate: 00000005 Verifying auth...ok Loading boot... INT_SYSRAM_BOOT test completed. Any errors manually select "ConnectMothods" and try again Connection type:brom Configuring DRAM... Waiting for DRAM detection... EMI Settings is now being prepared...OK Sending 2nd DA ... SYNC... OK 2nd DA...OK Retrieving RAM Configuration ... SRAM Size: 0x40000 DRAM Size: 0x80000000 Retrieving Memory Configuration ... EMMC CID : 150100524836344D42055D3FDE0F3477 EMMC Vendor: Samsung_RH64MB EMMC Size : 64GiB BOOT1 Size : 4 MiB BOOT2 Size : 4 MiB RPMB Size : 4 MiB User Area : 58.24 GiB Boot Completed. Checking userdata encryption... Userdata State : Encrypted Unlock / Relocking Screen Lock... Tip: first execution is unlock and the second is relock code=1 All done. Operation Done: 00:00:54 Avator Pro SW 2.4 |
The Following User Says Thank You to coderinside For This Useful Post: |
