AVATOR BOX (China Phones Service Tool) |
08-15-2011, 09:13 | #61 (permalink) |
No Life Poster Join Date: Feb 2010 Location: e.cameros shop Age: 45
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | first read info then readflash then format write good imei result thanks avatorbox team |
08-24-2011, 10:11 | #64 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Z2000 WHITESCREEN NO 112 SOLVE BY AVATORBOX PIC INSIDE first readinfo then readflash then format write tested imei result thanks avatorbox team |
08-27-2011, 04:23 | #65 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | 5130C spd Dead done by flashing via avatorbox pic inside first readinfo then format not work because firmware damage load tested firmware result thanks avatorbox team |
08-27-2011, 05:05 | #66 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Q8 invalid sim not solve auto reapir imei done by procedure first use tractker allways connecting time out second use imei load tested imei same problem allways connecting time out format fone write tested imei result thanks avatorbox team |
08-27-2011, 11:59 | #68 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | 1661 MT6219 invalid sim done another pinout picture inside fone repair by other shop not solve solve by me pinout write tested imei result thanks avatorboc team |
08-27-2011, 12:36 | #70 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | T23 myphone hang up message done by new update avatorbox pic inside readinfo then format then write orig imei result thanks avatorbox team by new update |
08-28-2011, 02:03 | #71 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | helo avator software is not bugs this MT6253 see this full working readflash format write flash or fullflash write imei result 1000% tested not bugs |
08-31-2011, 11:03 | #72 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | 1130 DEAD MT6253, NOR FLASH ID 00000000000 DONE PROCEDURE INSIDE FONE dead first readinfo pic inside not flash ic problem that logs reheat this after reheat and small shake nor flash id is good format fone write tested imei result ayos ba,... |
08-31-2011, 11:25 | #73 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | 1112 MT6217 HANGUP DONE PICTURE PINOUT INSIDE PINOUT MT6217 1112 FIRST READINFO NOT BOOT solution change lower boot read info then readflash then format Write tested imei result flash post me wait mode |
09-01-2011, 05:55 | #75 (permalink) |
Member: 1229604 Status: Offline Sonork: 100.1602688 Thanks Meter: 4,813 | Q4 hangup then off done via avatorbox pic inside first readifo then readflash then format write tested imei result thanks avatorbox team |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
