Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 09-28-2012, 09:07   #1 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
My avator box not ok
HI ON THIS TREAD I SAY MY BOX OK BUT NOT WORKING IN THE CABLE IF I USED THE RX TX MY BOX READIANG OK BUT WHEN I USED THE CABLE CANT DITECT PHONE ALWAY SAY
Initializing...
DA_LIB_VER_5.0.1.2
It is sensing the pinout fast,please hold on the phone Power key
RXD=1 TXD=2
Connecting...Please hold on the POWER key until the red gauge is going...
Any errors please select another boot and try again.
Failed to read HardCode, REG=0x80000008
Error: Failed to read REG=0x80010008
Error: Failed to read REG=0x84010008
Error: Failed to read REG=0x80001008
I I CONECT MY BOX ONLY NO CABLE WHEN CLICK SA START ALWAY SAY
Initializing...
DA_LIB_VER_5.0.1.2
RXD=1 TXD=2
NO CABLE AND NO PHONE MY BOX HAVE MECANICAL NOISE AND I THINK THE OUTFINDER HAVE SAMETHING PROBLEM
ANY IDIEA HOW TO FIX THIS THANK YOU
NOTE ALWAYS SAY THIS ERROR NO CABLE
GOT THIS ERROR
PLS HELP
Old 09-28-2012, 09:22   #2 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
Initializing...
DA_LIB_VER_5.0.1.2
RXD=1 TXD=2
Initializing...
DA_LIB_VER_5.0.1.2
RXD=1 TXD=2
GOT THIS ERROR
PLS HELP
what is fone model or check cpu chip brother
br
Old 09-28-2012, 09:53   #3 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
kahit wlang phone na nakalagay tol ganyan parin kahit wlang cable i click mo lang ung srart got eror na
then mecanicla noise,.
Old 09-29-2012, 00:29   #4 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
please update your box firmware then try again
[baka na convert mo dati sa ibang box ang avator box mo??]
br
Old 09-29-2012, 01:25   #5 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
im try yesterday to convert to other but juction error alwsy say i want to delete the old frmware in my box to update agien i alyws say i try to update more more time but nothing happen bro.
what this haedware problem but no one know how to fix and i used the pin by usb not resolder tx rx in main board.
Old 09-29-2012, 05:20   #6 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
bro use firmware 1.58 just solve your problem
DOWNLOAD
if you any problem contact me on yahoo
[email protected]
br
sarfraz husain
Old 09-29-2012, 05:30   #7 (permalink)
Member: 502531
Thanks Meter: 897
try also reinstall usb port driver on device manager
Old 09-29-2012, 05:41   #8 (permalink)
Member: 1449781
Sonork: 100.1662487
Thanks Meter: 13
are you sure that the phone is MTK????
Old 09-30-2012, 03:08   #9 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
RX: 3, TX: 4
Connecting...
Hardware version:8A04
Software version:8A01
CPU TYPE:6235
Internal version:0000
Boot downloading complete!
Flash ID: 00AD0076
Flash Type: NAND_HY27XS08121M
Chip Capacity: 0x4000000(64MB)
Mobile phone software version for:LUAZT01.8.52.1.0T06J1025_MB02
Baud adjust...complete.
>>Read phone information success.
info for my volcano
in my avator here
Initializing...
DA_LIB_VER_5.0.1.2
RXD=1 TXD=2
RXD=1 TXD=2 alway say not change,.
any one have idea pls or i start to flas my box in toilet
i try to update for many many times my box but notthing happen
Old 09-30-2012, 07:23   #10 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
now what this box its to careless in your box user
its to responsable in your user why you don give any good support and help
im so so Disappointed,
Old 09-30-2012, 12:31   #11 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
helo
avatorbox is good support
check your avatorbox supply
or give me teamviewer id and pass
i try to solved your problem
br
Old 09-30-2012, 14:15   #12 (permalink)
ernie78™'s Avatar
Member: 1229604
Sonork: 100.1602688
Thanks Meter: 4,813
helo
your box is solved problem here>>> http://forum.gsmhosting.com/vbb/8794474-post21.html
but now you post again your box is not working
why???????????
br
Old 09-30-2012, 20:34   #13 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
dear your selection in software wrong connect the properly tab and phone chip same are you sure
BR.
Arsalan gsm2000
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 10-01-2012, 13:14   #14 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
i have lot experince on volcano gpg drgon and avator.
my avator peoblem is the outo pinder if i used pin show the error but in rx tx in main board working fine why you dont get is esy to get even chipset is common copy
Old 10-01-2012, 13:21   #15 (permalink)
tartcell18's Avatar
Member: 1595088
Thanks Meter: 184
Page generated in 0.28488 seconds with 9 queries
