AVATOR BOX (China Phones Service Tool) |
03-24-2014, 09:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Elva Cellular - Indonesia
Member: 1386044 Status: Offline Thanks Meter: 65 | SC6530 WriteFlash Failed after Reset in AvatorBox Ver6.817 + SC Phone Brand: Cross T2 CPU : SC_6530 Flash: SF_GD27Q64 8MB Phone Condition before Reset: Hang, Touchscreen Not Work Phone Condition After Reset : DEAD (No Power On) ReadInfo, ReadFlash, Reset is OK Done but phone not power on after reset. I try to writeflash backup file or change file from same good phone, but always: Error: Failed to send request to phone. I think still any bugs on this update and i hope will solved on next update. Thank you BR. elvahape |
03-24-2014, 15:50 | #2 (permalink) | |
No Life Poster Join Date: Mar 2011 Location: GSM World!! Age: 35
Member: 1530237 Status: Offline Sonork: 100.1614868 Thanks Meter: 5,598 | Quote:
I will check and I will answer as soon as possible I have personally performed tests on SC6530 and all were satisfactory. | |
The Following User Says Thank You to resident2011 For This Useful Post: |
03-24-2014, 19:02 | #3 (permalink) | |
Insane Poster Join Date: Apr 2006 Location: Indonesia
Member: 267448 Status: Offline Thanks Meter: 10 | Quote:
CROSS T2 dead after format using Avator 6.733 CPU : SC_6530 Flash: SF_GD27Q64 8M. Error: Failed to send request to phone. | |
03-25-2014, 05:31 | #7 (permalink) | |
Member: 1386044 Status: Offline Thanks Meter: 65 | Quote:
6,45Mb. -This Readed File: Cross_T2_SC6530_SF_GD27Q64 - Download - 4shared -This Compressed file: Cross_T2_SC6530_SF_GD27Q64 - Download - 4shared | |
03-29-2014, 09:47 | #9 (permalink) | |
also SF_N25W0128 16MB have problem for reset or format, phone dead. Yes, i've been try ver6.733 but still problem. phone can live a normal life again when flashing using .pac file + original flasher. but we find it difficult to get the file .pac. | |
03-29-2014, 15:04 | #10 (permalink) | |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | Quote:
We try to find the phone with these Flash IDs in our local market . As soon as i will reply you . or i will try contact you in yahooo . for remote testing ... if you found any other phones with diffrent flash ID of SC6530 . Please report us .. Is this phones Are brand in your country ? | |
03-29-2014, 18:03 | #12 (permalink) | |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | Quote:
i will be eternally grateful | |
03-29-2014, 20:00 | #13 (permalink) | |
yes it is a local brand in Indonesia. To date only two cases for flash ID of SC6530, namely: SF_N25W0128 16MB (Asiafone AF-7997 and AF-7000) & SF_GD27Q64 8MB (Cross T2). I am always ready to report not instances of intractable cases by avatorbox. | |
The Following User Says Thank You to elvahape For This Useful Post: |
04-13-2014, 07:24 | #14 (permalink) | |
Member: 267448 Status: Offline Thanks Meter: 10 | MAXTRON MG-537 sprd6530 Dead After Format Quote:
LOG here Code: Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6530 Expert Mode=Disable Range[start]=0x0007B00 Range[size]=0x00800000 Interface=COM FlashFile=E:\2. AVATOR\Backup File\Maxtron_MG-537_SC6530_SF_GD27Q64.bin Comport=COM44 Baudrate=921600 CPU_Type=SC6530 CPU_ID=65300000 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=SF_GD27Q64 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_5.6.1.1 It is sensing the pinout fast... RXD=5 TXD=6 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6530000000006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Support br115200 on SC6610/20 & SC6530 only. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6530 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable Error: Failed to read ACK. +++++++++++++++++++End at: 4/13/2014 12:55:48 PM+++++++++++++++++++ -------------------Created: 4/13/2014 12:56:00 PM------------------- Chip=SpreadTrum Action=WriteFlash FlashType=NOR boot=6530 Expert Mode=Disable Range[start]=0x0007B00 Range[size]=0x00800000 Interface=COM FlashFile=E:\2. AVATOR\Backup File\Maxtron_MG-537_SC6530_SF_GD27Q64.bin Comport=COM44 Baudrate=460800 CPU_Type=SC6530 CPU_ID=65300000 NOR_ID=00C8006000170000 NOR_Size=8MB NOR_Name=SF_GD27Q64 NOR_DieCnt=1 NAND_ID= NAND_Size= NAND_Name= Initializing... DA_LIB_VER_5.6.1.1 It is sensing the pinout fast... RXD=5 TXD=6 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6530000000006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Support br115200 on SC6610/20 & SC6530 only. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6530 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable Error: Failed to read ACK. +++++++++++++++++++End at: 4/13/2014 12:56:41 PM+++++++++++++++++++ | |
04-14-2014, 04:19 | #15 (permalink) |
Member: 267448 Status: Offline Thanks Meter: 10 | Put Flash IC to SC6610 phone than write firmware Code: Initializing... DA_LIB_VER_5.6.1.1 It is sensing the pinout fast... RXD=5 TXD=6 Connecting... Connected...sending boot... FDL test...OK SC66x0 Unsupport OmnipotentMode in this time. ArmBootMode: 6610000000006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Support br115200 on SC6610/20 & SC6530 only. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... File System Ver: 0A IMEI 1=320812010411495 IMEI 2=910575601400468 ------Auto Format Address------- Start=0x005D8000 Size =0x00228000 Read FS info...done Initializing... DA_LIB_VER_5.6.1.1 It is sensing the pinout fast... RXD=5 TXD=6 Connecting... Connected...sending boot... FDL test...OK SC66x0 Unsupport OmnipotentMode in this time. ArmBootMode: 6610000000006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Support br115200 on SC6610/20 & SC6530 only. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
The Following User Says Thank You to Drajad For This Useful Post: |
