AVATOR BOX (China Phones Service Tool) |
05-16-2017, 17:39 | #61 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | BLU ADVANCE 4.0 L reset done Code: -------------------Created: 16/05/2017 3:03:25 PM------------------- Chip=MTK Action=ReadInfo FlashType=Nand boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=90014A483447326111 NAND_Size=4GB, usable capacity: 3.65GB NAND_Name=eMMC_Hynix_H4G2a Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 90014A483447326111 Read Hardware Information is done. Reading all android info... Hardware : MT6572_S01 brand : BLU Model : BLU ADVANCE 4.0 L Project Version : ALPS.KK1.MP7.V1 Software Vesion : ALPS.KK1.MP7.V1 Android Version : 4.4.2 CPU Architecture: armeabi-v7a Locale Region : US Language : en Build Date time: 29/04/2015 12:20:29 PM +++++++++++++++++++End at: 16/05/2017 3:03:32 PM+++++++++++++++++++ |
The Following User Says Thank You to onz For This Useful Post: |
05-16-2017, 17:45 | #62 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Gtel A713_Vivo_Pro read pattern lock Code: -------------------Created: 12/05/2017 12:40:47 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65800000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=150100463732324D42 NAND_Size=8GB, usable capacity: 7.29GB NAND_Name=eMMC_Samsung_F722MB Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6580, HardwareVer:CA00, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100463732324D42 Read Hardware Information is done. Reading all android info... Hardware : MT6580_S01 brand : Gtel Model : A713_Vivo_Pro Project Version : WBW5617TL_0201_T5815 Software Vesion : A713_Vivo_Pro Android Version : 5.1 CPU Architecture: armeabi-v7a Locale Region : US Language : en Build Date time: 02/11/2016 12:14:36 AM +++++++++++++++++++End at: 12/05/2017 12:40:54 PM+++++++++++++++++++ Code: -------------------Created: 12/05/2017 12:41:09 PM------------------- Chip=MTK Action=Read Pattern Lock FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65800000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=150100463732324D42 NAND_Size=8GB, usable capacity: 7.29GB NAND_Name=eMMC_Samsung_F722MB Initializing... DA_LIB_VER_7.0.1.0 Android : Read Pattern Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6580, HardwareVer:CA00, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 150100463732324D42 Read Hardware Information is done. Reading Pattern Code ... Read done, analysing ... 1 2 3 4 5 6 7 8 9 Code= 1532 Lock create date: 07/05/2017 2:51:07 PM +++++++++++++++++++End at: 12/05/2017 12:41:17 PM+++++++++++++++++++ |
05-23-2017, 09:48 | #63 (permalink) | ||
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | htm mobile a9 unlock done .................................................. ... Quote:
05-24-2017, 09:21 | #64 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | h-mobile v2 read full flash done Code: -------------------Created: 23/05/2017 5:24:49 PM------------------- Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Users\USER\Documents\H-MOBILE Comport=COM124 Baudrate=115200 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM35 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: C:\Users\USER\Documents\H-MOBILE.cmz All Done. +++++++++++++++++++End at: 23/05/2017 5:44:52 PM+++++++++++++++++++ |
05-31-2017, 18:05 | #66 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | astro mobile mercury read pattern done Code: -------------------Created: 31/05/2017 12:01:04 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65800000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=110100303034474530 NAND_Size=4GB, usable capacity: 3.69GB NAND_Name=eMMC_Toshiba_004GE0 Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM22 ] Connecting... Any errors please select another boot and try again. BB:6580, HardwareVer:CA00, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 110100303034474530 Read Hardware Information is done. Reading all android info... Hardware : MT6580_S01 brand : alps Model : gxq6580_weg_l Project Version : ALPS.L1.MP6.V2_GXQ6580.WEG.L_P69 Software Vesion : U210WE_V012En Android Version : 5.1 CPU Architecture: armeabi-v7a Locale Region : US Language : en Build Date time: 24/02/2017 1:25:39 PM +++++++++++++++++++End at: 31/05/2017 12:01:10 PM+++++++++++++++++++ Code: -------------------Created: 31/05/2017 12:02:15 PM------------------- Chip=MTK Action=Read Pattern Lock FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65800000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=110100303034474530 NAND_Size=4GB, usable capacity: 3.69GB NAND_Name=eMMC_Toshiba_004GE0 Initializing... DA_LIB_VER_7.0.1.0 Android : Read Pattern Lock Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM22 ] Connecting... Any errors please select another boot and try again. BB:6580, HardwareVer:CA00, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 110100303034474530 Read Hardware Information is done. Reading Pattern Code ... Read done, analysing ... 1 2 3 4 5 6 7 8 9 Code= 45863 Lock create date: 29/05/2017 10:29:46 PM +++++++++++++++++++End at: 31/05/2017 12:02:22 PM+++++++++++++++++++ |
05-31-2017, 18:07 | #67 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | H-mobile v9 pin removal done Code: -------------------Created: 30/05/2017 2:02:30 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM139 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! All done. +++++++++++++++++++End at: 30/05/2017 2:02:40 PM+++++++++++++++++++ Code: -------------------Created: 30/05/2017 2:17:25 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM35 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 15 secret keys have been killed. All Done. +++++++++++++++++++End at: 30/05/2017 2:20:01 PM+++++++++++++++++++ |
05-31-2017, 18:18 | #68 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | sm SM-G930F auto off solved by format Code: -------------------Created: 31/05/2017 7:12:16 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=7001004D4D43303447 NAND_Size=4GB, usable capacity: 3.61GB NAND_Name=eMMC_Kingston_KE4CN2L2HA8A2A Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM39 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x0000000020000000 Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 7001004D4D43303447 Read Hardware Information is done. Reading all android info... Hardware : MT6572_S01 brand : Samsung Model : SM-G930F Project Version : S7272_3G_6.0.1_V2.0 20170216-1458 Software Vesion : S7272_3G_6.0.1_V2.0 Android Version : 4.2.2 CPU Architecture: armeabi-v7a Locale Region : US Language : en Build Date time: 16/02/2017 2:58:37 PM +++++++++++++++++++End at: 31/05/2017 7:12:40 PM+++++++++++++++++++ Code: -------------------Created: 31/05/2017 7:14:38 PM------------------- Chip=MTK Action=Format FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=7001004D4D43303447 NAND_Size=4GB, usable capacity: 3.61GB NAND_Name=eMMC_Kingston_KE4CN2L2HA8A2A Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM39 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Warning: failed to init dram, loading default settings Waiting for DRAM detection... Done. Size=0x0000000020000000 Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 7001004D4D43303447 Read Hardware Information is done. Formatting Flash... All Done +++++++++++++++++++End at: 31/05/2017 7:14:59 PM+++++++++++++++++++ |
05-31-2017, 18:20 | #69 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | iphone 7 plus reset all settings done Code:
Code: -------------------Created: 31/05/2017 7:10:17 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65820000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=1501004E35575A4D42 NAND_Size=4GB, usable capacity: 3.64GB NAND_Name=eMMC_Samsung_KMN5W000ZM_B207 Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6582, HardwareVer:CA01, SoftwareVer:0001 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 1501004E35575A4D42 Read Hardware Information is done. Reading all android info... Hardware : MT6582_S01 brand : Apple Model : lPHONE Project Version : ALPS.JB5.MP.V1.27 Software Vesion : ALPS.JB5.MP.V1.27 Android Version : 4.2.2 CPU Architecture: armeabi-v7a Locale Region : GB Language : en Build Date time: 16/01/2017 10:48:48 AM +++++++++++++++++++End at: 31/05/2017 7:10:22 PM+++++++++++++++++++ -------------------Created: 31/05/2017 7:10:50 PM------------------- Chip=MTK Action=Reset all settings FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=MT65820000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=1501004E35575A4D42 NAND_Size=4GB, usable capacity: 3.64GB NAND_Name=eMMC_Samsung_KMN5W000ZM_B207 Initializing... DA_LIB_VER_7.0.1.0 Android : Reset all settings Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6582, HardwareVer:CA01, SoftwareVer:0001 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 1501004E35575A4D42 Read Hardware Information is done. Formatting Flash... All Done +++++++++++++++++++End at: 31/05/2017 7:11:04 PM+++++++++++++++++++ |
06-07-2017, 16:56 | #70 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | vdf 100 reset done Code: -------------------Created: 07/06/2017 1:43:53 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Ver5.1232 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT6260 CPU_ID=00000000 NOR_ID=00EF004000160000 NOR_Size=4MB NOR_Name=[WINBOND] W25Q32BV NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM41 ] Connecting... Any errors please select another boot and try again. BB:6260, HardwareVer:8000, SoftwareVer:CB00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 00EF004000160000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. +++++++++++++++++++End at: 07/06/2017 1:44:08 PM+++++++++++++++++++ -------------------Created: 07/06/2017 2:45:30 PM------------------- Chip=MTK Action=Format FlashType=NOR boot=Ver5.1232 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT6260 CPU_ID=00000000 NOR_ID=00EF004000160000 NOR_Size=4MB NOR_Name=[WINBOND] W25Q32BV NOR_DieCnt= NAND_ID=0000000000000000 NAND_Size=0MB NAND_Name=Nand:N/A Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM31 ] Connecting... Any errors please select another boot and try again. BB:6260, HardwareVer:8000, SoftwareVer:CB00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Loading boot... Boot3 test completed. Nor Flash ID: 00EF004000160000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Formatting Flash... All Done +++++++++++++++++++End at: 07/06/2017 2:45:52 PM+++++++++++++++++++ |
06-07-2017, 16:59 | #71 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | alcatel frp reset done Code: -------------------Created: 07/06/2017 12:32:44 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=FE014E50314A39344D NAND_Size=4GB, usable capacity: 3.65GB NAND_Name=EMMC_Device_P1J94M Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: FE014E50314A39344D Read Hardware Information is done. Reading all android info... Build Date time: 10/08/2016 11:22:58 PM +++++++++++++++++++End at: 07/06/2017 12:32:51 PM+++++++++++++++++++ -------------------Created: 07/06/2017 12:33:06 PM------------------- Chip=MTK Action=Reset all settings FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=FE014E50314A39344D NAND_Size=4GB, usable capacity: 3.65GB NAND_Name=EMMC_Device_P1J94M Initializing... DA_LIB_VER_7.0.1.0 Android : Reset all settings Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: FE014E50314A39344D Read Hardware Information is done. Formatting Flash... FRP Partition found, erasing ... All Done +++++++++++++++++++End at: 07/06/2017 12:33:22 PM+++++++++++++++++++ |
06-07-2017, 17:01 | #72 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Hisense u602 frp reset done Code: -------------------Created: 06/06/2017 2:20:28 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT65800000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=700100563130303038 NAND_Size=8GB, usable capacity: 7.05GB NAND_Name=eMMC_Kingston_V10008 Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6580, HardwareVer:CA00, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 700100563130303038 Read Hardware Information is done. Reading all android info... Hardware : MT6580_S01 brand : Hisense Model : HS-U602 Project Version : ALPS.L1.MP6.V2_AUS6580.WE.L_P19 Software Vesion : U602E-1_M00_S02 Android Version : 5.1 CPU Architecture: armeabi-v7a Locale Region : US Language : en Build Date time: 23/09/2015 7:18:32 PM +++++++++++++++++++End at: 06/06/2017 2:20:36 PM+++++++++++++++++++ -------------------Created: 06/06/2017 2:20:50 PM------------------- Chip=MTK Action=Reset all settings FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT65800000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=700100563130303038 NAND_Size=8GB, usable capacity: 7.05GB NAND_Name=eMMC_Kingston_V10008 Initializing... DA_LIB_VER_7.0.1.0 Android : Reset all settings Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6580, HardwareVer:CA00, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: 700100563130303038 Read Hardware Information is done. Formatting Flash... FRP Partition found, erasing ... All Done +++++++++++++++++++End at: 06/06/2017 2:21:06 PM+++++++++++++++++++ |
06-07-2017, 17:03 | #73 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | another vdf 100 done Code: -------------------Created: 05/06/2017 12:42:47 PM------------------- Chip=MTK Action=ReadInfo FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=FE014E50314A39344D NAND_Size=4GB, usable capacity: 3.65GB NAND_Name=EMMC_Device_P1J94M Initializing... DA_LIB_VER_7.0.1.0 Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: FE014E50314A39344D Read Hardware Information is done. Reading all android info... Build Date time: 24/01/2017 7:05:57 PM +++++++++++++++++++End at: 05/06/2017 12:42:54 PM+++++++++++++++++++ -------------------Created: 05/06/2017 12:43:12 PM------------------- Chip=MTK Action=Reset all settings FlashType=NOR boot=Smart Phone Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=MT65720000 CPU_ID= NOR_ID=0000000000000000 NOR_Size=0MB NOR_Name=Nor:N/A NOR_DieCnt= NAND_ID=FE014E50314A39344D NAND_Size=4GB, usable capacity: 3.65GB NAND_Name=EMMC_Device_P1J94M Initializing... DA_LIB_VER_7.0.1.0 Android : Reset all settings Tips: 1.Remove Battery, Insert usb cable, Insert battery 2.power off Phone, Remove & Reinsert Battery , insert USB Cable (In Case Some Phone Required to hold bootkey) Waiting for Phone Usb... Phone found [ USB Port:COM6 ] Connecting... Any errors please select another boot and try again. BB:6572, HardwareVer:CA01, SoftwareVer:0000 Loading boot... INT_SYSRAM_BOOT test completed. Auto changing FlashType to eMMC mode Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 eMMC cid: FE014E50314A39344D Read Hardware Information is done. Formatting Flash... FRP Partition found, erasing ... All Done +++++++++++++++++++End at: 05/06/2017 12:43:28 PM+++++++++++++++++++ |
06-07-2017, 17:07 | #74 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | m-horse mobile unlocked Code: -------------------Created: 05/06/2017 12:30:04 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=002C00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_MT29F4G08ABC_2 Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM87 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_MT29F4G08ABC_2 setting the Flash Parameters... Settings have been completed! All done. ++++++++++++ Code: -------------------Created: 05/06/2017 12:30:59 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=002C00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_MT29F4G08ABC_2 Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM87 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_MT29F4G08ABC_2 setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 40 secret keys have been killed. All Done. +++++++++++++++++++End at: 05/06/2017 12:33:32 PM+++++++++++++++++++ |
06-07-2017, 17:30 | #75 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Mint mobile gmail lock done Code: -------------------Created: 03/06/2017 12:06:32 PM------------------- Chip=SpreadTrum Action=ReadInfo FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM30 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! All done. +++++++++++++++++++End at: 03/06/2017 12:06:42 PM+++++++++++++++++++ -------------------Created: 03/06/2017 12:07:09 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM30 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 48 secret keys have been killed. All Done. +++++++++++++++++++End at: 03/06/2017 12:09:40 PM+++++++++++++++++++ |
