AVATOR BOX (China Phones Service Tool) |
07-17-2017, 08:33 | #92 (permalink) |
No Life Poster Join Date: Aug 2013 Location: Bulawayo zimbabwe
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | M-horse v8 pin code removed Code: -------------------Created: 13/07/2017 4:58:13 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM124 Baudrate=115200 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00AD00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_H8BCS0UN0MCR Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM87 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_H8BCS0UN0MCR setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 231 secret keys have been killed. All Done. +++++++++++++++++++End at: 13/07/2017 5:00:46 PM+++++++++++++++++++ |
The Following User Says Thank You to onz For This Useful Post: |
07-17-2017, 08:34 | #93 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Htc q918 pin removed Code: -------------------Created: 13/07/2017 12:14:13 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00EC00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_K9K4G16Q0M Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM87 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_K9K4G16Q0M setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 19 secret keys have been killed. All Done. +++++++++++++++++++End at: 13/07/2017 12:16:52 PM+++++++++++++++++++ |
The Following 2 Users Say Thank You to onz For This Useful Post: |
07-17-2017, 08:39 | #94 (permalink) |
Member: 2012334 Status: Offline Sonork: 100.1658100 Thanks Meter: 777 | Mint mobile pattern removed Code: -------------------Created: 13/07/2017 12:14:13 PM------------------- Chip=SpreadTrum Action=Unlock FlashType=Nand boot=7710 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile= Comport=COM91 Baudrate=115200 CPU_Type=SC8810 CPU_ID=88100040 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00EC00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_K9K4G16Q0M Initializing... DA_LIB_VER_7.0.1.0 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... SCI USB Device found. USB=COM87 Connecting... Bootstrap: SPRD3 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 115200 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810004000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC8810 Flash: NAND_K9K4G16Q0M setting the Flash Parameters... Settings have been completed! Running Tracker of Android... 19 secret keys have been killed. All Done. +++++++++++++++++++End at: 13/07/2017 12:16:52 PM+++++++++++++++++++ |
