Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > AVATOR BOX
AVATOR BOX (China Phones Service Tool)
Old 11-16-2014, 02:56   #1 (permalink)
Member: 779599
Thanks Meter: 59
team pls help how to remove pattern using avator tool
team pls give me a guide how to use avator tool i try to open avator exe tool but the phone didnt connect i click removed pattern but the phone didnt connect
heres the logs
Application: 1.0.0.15
Model: Autodetect
Request information...
Searching Phone...
Timeout
USB Debug should be Enabled !
this is the second log
using box
Initializing...
DA_LIB_VER_5.9.0.0
MTK USB Device found. Port=COM7
Connecting...
Any errors please select another boot and try again.
BB:6572, HardwareVer:CA01, SoftwareVer:0000
Loading boot...
INT_SYSRAM_BOOT test completed.
Loading boot...
Boot2 test completed.
Nor Flash ID: 0000000000000000
Nand Flash ID: 009800BC009000660076
eMMC cid: 000000000000000000
Error: unknow PartTbl.
Error: failed to read PartTbl.
Read Hardware Information is done.
3rd i try to format but there is an error no success
heres th logs
Initializing...
DA_LIB_VER_5.9.0.0
Connecting...
Loading boot...
Loading boot...
Formatting Flash...
Old 11-16-2014, 03:29   #2 (permalink)
Member: 779599
Thanks Meter: 59
wher are you team pls give me solution i try to use this many times but it doesnt work but when i change imei most phone easily connected using this tool pls give me a guide
Old 11-16-2014, 03:40   #3 (permalink)
Momin_Telecom's Avatar
Member: 1478271
Sonork: 100.1608386
Thanks Meter: 1,806
heres the logs
Model: Autodetect
Searching Phone...
Timeout
using box
Initializing...
DA_LIB_VER_5.9.0.0
Connecting...
Loading boot...
Loading boot...
heres th logs
Initializing...
DA_LIB_VER_5.9.0.0
Connecting...
Loading boot...
Loading boot...
Formatting Flash...
Dear brother follow this step and see that magic of Avator teem http://forum.gsmhosting.com/vbb/10668287-post2.html
Old 11-16-2014, 04:14   #4 (permalink)
Member: 779599
Thanks Meter: 59
sad to say again phone doesnt i try to use that trick but it doesnt connect when i click info it is connected but when i click imei and android and start it doesn connect
heres the logs
Initializing...
DA_LIB_VER_5.9.0.0
Tip: The phone must be able to power-on normally
this time the phone is connect by selecting meta
heres the logs
Initializing...
DA_LIB_VER_5.9.0.0
Connecting...
User abort, freeing Download Agent, please wait...
The process stopped.
but when i open avator he ask dongle so i remove and insert then i try your suggestion when i click remove pattern again the phone doesnt connect it gives me a headache
heres the logs
Model: Autodetect
Searching Phone...
Timeout
no good pls help
Old 11-16-2014, 06:29   #5 (permalink)
..:\\lucky//:..'s Avatar
Member: 1864000
Thanks Meter: 2,893
no good pls help
You can do it very easily using factory mode .
http://forum.gsmhosting.com/vbb/f652...ongle-1863683/
http://forum.gsmhosting.com/vbb/f652...nside-1837167/
http://forum.gsmhosting.com/vbb/f652...-safe-1868596/
Wbr
..:\\lucky//:..
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post:
Old 11-18-2014, 03:09   #6 (permalink)
Member: 779599
Thanks Meter: 59
team thank you now i have an idea how to use avator tool
The Following User Says Thank You to jethcell For This Useful Post:
Page generated in 0.20475 seconds with 8 queries
