AVATOR BOX (China Phones Service Tool) |
01-15-2015, 17:35 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Test Report After Free Activation {Hitech Care} [solved & clear ] Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=6820 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=F:\A62 OK Comport=COM3 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=002C00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_MT29F4G08ABC_2 Initializing... DA_LIB_VER_6.1.0.5 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Connected...sending boot... Spd USB-to-Serial=COM10 Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_MT29F4G08ABC_2 setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: F:\A62 OK.cmz All Done. |
01-26-2015, 14:25 | #5 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Quote:
http://www.dailymotion.com/video/x1u...tar-tab_webcam | |
01-26-2015, 17:14 | #6 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | Quote:
In ANDROID phones you USE ONLY usb cable.. if you need a MAGICAL CABLE, yes we have for you.. http://forum.gsmhosting.com/vbb/f652...users-1893516/ | |
The Following User Says Thank You to maomatrix For This Useful Post: |
01-26-2015, 23:25 | #7 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | As u both know micromax a67 having diff USB pinout .....scnd i not ask how to boot with usb cable....i know about auto boot cable i m having all this... |
01-26-2015, 23:28 | #8 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Chip=SpreadTrum Action=ReadFlash FlashType=Nand boot=6820 Expert Mode=Disable Range[start]=0x0 Range[size]=0x0 Interface=USB FlashFile=C:\Documents and Settings\SERVICE WORLD\Desktop\A27 COPY Comport=COM91 Baudrate=921600 CPU_Type=88100001 CPU_ID=88100001 NOR_ID= NOR_Size= NOR_Name= NOR_DieCnt= NAND_ID=00EC00BCFFFFFFFF NAND_Size=512MB NAND_Name=NAND_K9K4G16Q0M Initializing... DA_LIB_VER_6.1.0.5 You must install the correct USB drivers before any actions... You will see a new ComPort: SCI USB2Serial(COMxx) in PC Device Manager -> Ports... Auto reset and search the USB-to-Serial... Connecting... Spd USB-to-Serial=COM47 Connected...sending boot... Boot1 is Done. Wait for ACK... Done. Change baud to 921600 Sending Boot2... Boot2 is Done. Wait for ACK... Done. ArmBootMode: 8810000100005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: 88100001 Flash: NAND_K9K4G16Q0M setting the Flash Parameters... Settings have been completed! Reading Flash... Save as: C:\Documents and Settings\SERVICE WORLD\Desktop\A27 COPY.cmz All Done. |
The Following User Says Thank You to hitech care For This Useful Post: |
