AVATOR BOX (China Phones Service Tool) |
05-07-2015, 09:41 | #4 (permalink) | ||
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Quote:
-This is a Chinese SPD phone Quote:
Not Working see photo below Last edited by Kirumira; 05-07-2015 at 09:44. Reason: spelling | ||
05-07-2015, 10:02 | #5 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: (Tech land)
Member: 1864000 Status: Offline Thanks Meter: 2,893 | Quote:
http://avatorbox.com/avator-7.902.rar | |
The Following User Says Thank You to ..:\\lucky//:.. For This Useful Post: |
05-07-2015, 10:40 | #6 (permalink) |
No Life Poster Join Date: Jan 2010 Location: China
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | not sure SPD6825/8825 Too many Pattern lock In our Test phones . we try to wrong Patten more than 125times . but still Not shows Too many patten locks I suggest you ., please read Flash first and try to unlock with Avator ., if not done ., please send us Read Flash with avator . we will check it |
05-07-2015, 11:31 | #7 (permalink) | |
How can I Read Flash when Info is Wrong ?? See Photo below Otherwise thank you All Supporters but the War is still continuing Last edited by Kirumira; 05-07-2015 at 11:34. Reason: some spellings | |
05-07-2015, 12:05 | #9 (permalink) | |
Second thing , too many pattern or gmail locks of 8825 cpu is not supported no need try again on main suite except making root ,make debugg on and do by avator dongle tool. If you are expert technician , if you can root this model , if you can make debugg on , sure gmail lock can be remove by dongle version.Other wise choice is yours. | |
05-07-2015, 12:18 | #10 (permalink) | |
No Life Poster Join Date: Oct 2008 Location: INDIA/CHINA/HONGKONG Age: 33
Member: 1023528 Status: Offline Sonork: 100.1594367 Thanks Meter: 1,376 | Quote:
Br Puneet5154-AvatorBox HelpDesk | |
05-07-2015, 14:47 | #11 (permalink) | |
In this situation expert mode can help you but many users do not know how to use expert mode option. -Brothers expert mode is not supported for SPD6825/8825 Second thing , too many pattern or gmail locks of 8825 cpu is not supported no need try again on main suite except making root ,make debugg on and do by avator dongle tool. -Once again i tried Rooting this Phone using Avatordongle with all six Methods but Totally failed If you are expert technician , if you can root this model , if you can make debugg on , sure gmail lock can be remove by dongle version.Other wise choice is yours. -Finally Avatorbox/dongle Failed to Help me. Now i wipe data/Reset the Phone is now ok. but Again I enabled Usb debugging/Unknown sources, to ROOT it Again But FAILED completely. THANKS TO U ALL AVATORBOX TEAM FOR YOUR SUPPORT THIS IS NOT THE END KEEP ON RESEARCHING ABOUT THESE SPD CPUS. AVATORBOX/DONGLE A TRUE BOX IN ALL SEASONS REGARDS Last edited by Kirumira; 05-07-2015 at 14:49. Reason: some spellings | |
05-07-2015, 14:58 | #12 (permalink) | |
05-07-2015, 17:44 | #13 (permalink) |
Member: 1222089 Status: Offline Sonork: 100.1583019 Thanks Meter: 2,688 | It's shows 4mb., its beta exe calculate missing the size., but you can read flash the phone, Make it too many pattern lock and read flash and send me ., will be support in next update may be |
