05-25-2011, 18:51 | #1 (permalink) |
No Life Poster Join Date: Feb 2010 Location: GHANA
Member: 1240625 Status: Offline Sonork: LABISTA Thanks Meter: 48 | 6710s sim not valid Detected card sn: 0pppppppppppp Card version: 00.09 Life counter: 99.43% Fenix Reader SW version: 0.0.2 Connection interface is set to USB now. No phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-491 MCU SW Version: V ICPR82_09w24 12-06-09 RM-491 (c) Nokia Imei: 354201031075548 Product code: 0588603 Simlock status: Profile bits: 8000000000000000 Config key: 2140700000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 40 7F Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 40 2F Looking for flash files No flash files found for selected product Job's finished successfully! Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695 CMT Hw ID: 600C192102011104 CMT Boot ROM CRC: 3E273BF6 CMT Secure ROM CRC: 37BE26FA CMT Public Id: 1DA0010AFD5E034498FD1D678603FC72FEFD07A6 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Reading phone data Reading codes... An error occurred: No simlock block found Job's finished with errors! No phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-491 MCU SW Version: V ICPR82_09w24 12-06-09 RM-491 (c) Nokia Imei: 354201031075548 Product code: 0588603 Simlock status: Profile bits: 8000000000000000 Config key: 2140700000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 40 7F Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 40 2F Looking for flash files No flash files found for selected product Job's finished successfully! Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695 CMT Hw ID: 600C192102011104 CMT Boot ROM CRC: 3E273BF6 CMT Secure ROM CRC: 37BE26FA CMT Public Id: 1DA0010AFD5E034498FD1D678603FC72FEFD07A6 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Generating RPL... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Writing RPL... An error occurred: RPL could not be accepted Job's finished with errors! Powering off the phone Aborting job... Software will abort the job as soon as possible and it might take a while. Job has been aborted by user! Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695 CMT Hw ID: 600C192102011104 CMT Boot ROM CRC: 3E273BF6 CMT Secure ROM CRC: 37BE26FA CMT Public Id: 1DA0010AFD5E034498FD1D678603FC72FEFD07A6 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Reading phone data Reading codes... An error occurred: No simlock block found Job's finished with errors! Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695 CMT Hw ID: 600C192102011104 CMT Boot ROM CRC: 3E273BF6 CMT Secure ROM CRC: 37BE26FA CMT Public Id: 1DA0010AFD5E034498FD1D678603FC72FEFD07A6 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Generating SD keys... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Writing SD keys... Setting normal mode Job's finished successfully! Checking connection... Reading phone info Product type: RM-491 MCU SW Version: V ICPR82_09w24 12-06-09 RM-491 (c) Nokia Imei: 354201031075548 Product code: 0588603 Simlock status: Profile bits: 8000000000000000 Config key: 2140700000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 40 7F Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 21 40 2F Looking for flash files No flash files found for selected product Job's finished successfully! SL3 Unlocking started (via USB) Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695 CMT Hw ID: 600C192102011104 CMT Boot ROM CRC: 3E273BF6 CMT Secure ROM CRC: 37BE26FA CMT Public Id: 1DA0010AFD5E034498FD1D678603FC72FEFD07A6 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Reading phone data Setting normal mode Job's finished successfully! PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695 CMT Hw ID: 600C192102011104 CMT Boot ROM CRC: 3E273BF6 CMT Secure ROM CRC: 37BE26FA CMT Public Id: 1DA0010AFD5E034498FD1D678603FC72FEFD07A6 Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Reading phone data Reading codes... An error occurred: No simlock block found Job's finished with errors! |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
