6120 unlock error.pls help Software version: 1.0.9 Detected card sn: xxxxxxxx Card version: 00.09 Life counter: 99.6% Fenix Reader SW version: 0.0.2 Connection interface is set to USB now. No phone found. Connect your phone using USB cable and try again. No phone found. Connect your phone using USB cable and try again. No phone found. Connect your phone using USB cable and try again. No phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-243 MCU SW Version: V 07.10 15-07-09 RM-243 (c) Nokia Imei: 351983042007965 Product code: 0567116 Simlock status: Profile bits: 0000000000000000 Config key: 5050100058056920 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 50 50 1F Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 50 50 1F Looking for flash files Flash files found for selected product Job's finished successfully! Powering off the phone PLEASE PRESS PHONE`S POWER BUTTON CMT Hash : 479C6DDE3942E12C429C1D6ADED80371 CMT Hw ID: 400C192101051103 CMT Boot ROM CRC: 4B9B7510 CMT Secure ROM CRC: 3E691FF8 CMT Public Id: 1AA0010EFF8E00521F6703E89D49F716BE2DD54E Preparing bootstrap to use USB BootMedia Sending RAW 2ND Initializing... Trying to set test mode automatically... Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer. Disconnected from the device Waiting for phone... Connected to the device Setting test mode Reading phone data Reading codes... An error occurred: Cannot decrypt security block Job's finished with errors! |
Same problem with me bro, always errors? I have unlocked Nokia 6120 V 07.10 Hash : 47XXX with other tool. Hope it will be fix by Fenix Key Team...? |
