05-30-2011, 12:54 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Weston-super-Mare, UK Age: 40
Member: 198717 Status: Offline Thanks Meter: 16 | BruteForce Problems after 12 Hours.. Any ideas? |
05-30-2011, 15:15 | #4 (permalink) |
No Life Poster Join Date: Mar 2005 Location: cebu city
Member: 126086 Status: Offline Sonork: 100.113901 Thanks Meter: 232 | @ this setting you need to have a stable voltage of you gpu..your overclock is to high for a stock fans...you also having trouble of ati driver @ this overclock..880 is the perfect overclock for me.. |
05-30-2011, 15:41 | #5 (permalink) |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | I think.. After 12 hs, not is a problem of OC. Is a Temp (hot) problem or non Stability voltage ..... Look in the Bios all parametter About range temp / cpu/gpu / Cooler (power off Q-Fan Control must be Power off) After 12 hs is a strange problem... b/r the_polack |
06-01-2011, 15:19 | #7 (permalink) |
Member: 198717 Status: Offline Thanks Meter: 16 | Just to report back, I read on a forum disabling the onboard audio on Asus boards can make a difference and I also downloaded a patched driver from AMD/ATI that was released on the 25th May... I'm so far running 15.5hrs.... Hope this helps anyone with the same problems. |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
unlocking nokia 5110 version5.12 5.20 | tomi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 02-25-2011 10:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
