Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Fenix Key
Old 12-15-2012, 11:53   #1 (permalink)
Member: 985391
Thanks Meter: 12
No phone found.
Hello im new to fenix and nokia usb flashing and unlocking
i recive my fenix today and i was trying to work with a phone a 5130 phone battery fully charge but when trying to connect the phone recieve the same error.
No phone found. Connect your phone using USB cable and try again.
please if any one can help my
Software version: 1.2.1
Detected card sn: xxxxxx
Card version: 01.00
Life counter: 100%
Fenix Reader SW version: 0.0.2
Connection interface is set to USB now.
thank you
Old 12-15-2012, 11:58   #2 (permalink)
Javed ajmeri's Avatar
Member: 424082
Thanks Meter: 128
Arrow
check usb connector & ic
or
flash it with f-bus cable
Old 12-15-2012, 12:08   #3 (permalink)
matcom gsm's Avatar
Member: 106346
Sonork: 100.1577684
Thanks Meter: 1,061
Card version: 01.00
Life counter: 100%
thank you
This problem Ώĩ†̥ђ driver install latest pc suite and post result better work Ώĩ†̥ђ fbus cable if installing driver problem persist
Old 12-16-2012, 12:41   #4 (permalink)
Member: 985391
Thanks Meter: 12
phone only reads if on
thank you hi i have this problem with fenix key if the phone is on and when you select pc suite on phone then it reads same phone with the security code on No phone found. Connect your phone using USB cable and try again.
Detected card sn:
Card version: 01.00
Life counter: 100%
Checking connection...
Reading phone info
Product type: RM-635
MCU SW Version:
V 10.10
22-04-10
RM-635
(c) Nokia
PPM Version:
V 10.10
22-04-10
RM-635
(c) Nokia
M_H
Content Pack Version:
Content: m_h_black
V 10.10
22-04-10
RM-635
(c) Nokia
Imei: 354305041604740
Product code: 0592082
Simlock status:
Profile bits: 0000000000000000
Config key: 2440700000000000
Fbus codes typed: 0/10
Key codes typed: 0/3
Block 1:
Lock 1: OPEN(IMSI); TYPE: 5; DATA: FF FF FF
Lock 2: OPEN(GID1); TYPE: 1; DATA: FF FF
Lock 3: OPEN(GID2); TYPE: 1; DATA: FF FF
Lock 4: OPEN(IMSI); TYPE: 5; DATA: FF FF FF FF FF FF FF FF
Lock 5: OPEN(IMSI); TYPE: 5; DATA: FF FF FF FF FF FF FF FF
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Analyzing profile bits...
This phone can be unlocked via keyboard and fbus
Looking for flash files
No flash files found for selected product
Job's finished successfully!
thank you
Page generated in 0.17700 seconds with 9 queries
