Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Fenix Key
Old 03-13-2012, 12:56   #286 (permalink)
Member: 1709328
error flashing
i tried to flash nokia e72, i get this error, can u please tell me what the problem:
Flashing started
Battery voltage: 3924mV
Reading important PM fields
Checking connection
Field received. ID = 120
Field received. ID = 308
PM backup saved as: C:\Documents and Settings\Box\Mes documents\Lavarow\Fenix\Backup\Pm\357895040121297-13-03-2012 11-49-08.pm
CMT Flash: SAMSUNG (SEC) - Unknown product
Setting flash mode
Aborting job... Software will abort the job as soon as possible and it might take a while.
Job has been aborted by user!
Flashing started
Battery voltage: 3944mV
Checking connection
PM backup saved as: C:\Documents and Settings\Box\Mes documents\Lavarow\Fenix\Backup\Pm\357895040121297-13-03-2012 11-51-10.pm
Setting flash mode
CMT Hash : 25B977A055BE9B5DEC0C38A2A279C695
CMT Hw ID: 600C192102011104
CMT Boot ROM CRC: 3E273BF6
CMT Secure ROM CRC: 37BE26FA
CMT Public Id: 122000013BD903449ED24029DA07BF8E7CCBD96B
CMT Papubkeys: 660D81A4455F6F7F9B81D5D10F5336B1
Preparing *****trap to use USB BootMedia
Sending RAW 2ND
Sending RAW ALGO
Communication error
Job's finished with errors!
Old 03-13-2012, 13:42   #287 (permalink)
piracik's Avatar
Member: 133762
Try with another cable or dead option
Old 03-13-2012, 14:43   #288 (permalink)
Member: 1709328
same result
same result, what the problem, Nokia e72-rm530 is not supported by fenix key
or what?
Old 03-13-2012, 19:08   #289 (permalink)
matcom gsm's Avatar
Member: 106346
Sonork: 100.1577684
read here always
SUPPORTED PHONES LIST by FENIX KEY & SLAP SL3 BF
br
matcom gsm
Old 03-13-2012, 19:37   #290 (permalink)
piracik's Avatar
Member: 133762
or what?
Supported 100% tested on few units
It's problem with Your computer or cable.
Always use oryginal usb cable - if not working check on anothers Usb port - if not working install newest Nokia drivers - if not working reinstal system or check on another computer
BTW.
I've got short Usb cable ~15cm and most phones work OK, some works on 40cm cable but not all, and some works on oryginal LG or Samsung cables; so that can be an issue
The Following User Says Thank You to piracik For This Useful Post:
Old 04-06-2012, 11:33   #291 (permalink)
Member: 1250893
plese help me, If you want to use JAF/UFS interface install latest drivers!!!!!!!
i have last hwk drivers. think you
Old 04-10-2012, 12:22   #292 (permalink)
Member: 171545
Exe problem Slap
The Following User Says Thank You to ramazan.keskin For This Useful Post:
Old 09-22-2012, 02:59   #293 (permalink)
Member: 1352686
hi sir..
i just bought fenix key today.
and i face this problem..
when i insert to computer ..
there are not smart card..
can teach?
Old 09-25-2012, 16:40   #294 (permalink)
Member: 1756774
hi
i flashed correctly nokia 5130 xm but phone dont switch on. if i power it shows nokia logo and white screen (that was the initial problem).
sorry for bad english/ i am senegalese man
Old 11-17-2012, 15:24   #295 (permalink)
drbilal's Avatar
Member: 213808
Sonork: 100.1615441:drbilal
log read error of 6303
Analyzing profile bits...
This phone can be unlocked via keyboard and fbus
Looking for flash files
No flash files found for selected product
Access violation at address 004E3217 in module 'fenix.exe'. Read of address 00000000
Checking connection...
Reading phone info
Product type: RM-638
MCU SW Version:
V 07.10
25-03-10
RM-638
(c) Nokia
PPM Version:
V 07.10
25-03-10
RM-638
(c) Nokia
OC
Content Pack Version:
Content: orange UK
V 07.10
25-03-10
RM-638
(c) Nokia
Imei: 353797xxxxxxxxx
Product code: 059B2H7
Simlock status:
Profile bits: 8000000000000000
Config key: 2343300000000000
Fbus codes typed: 0/10
Key codes typed: 0/3
Block 1:
Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 23 43 3F
Block 2:
Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 23 48 6F
Job's finished successfully!
SL3 Unlocking started (via USB)
Reading phone data
Powering off the phone
PLEASE PRESS PHONE`S POWER BUTTON
CMT Hash : 7B045400E1752022F9EB80B0DEA9C65D
CMT Hw ID: 020C192102054100
CMT Boot ROM CRC: 67E82268
CMT Secure ROM CRC: F29CEA60
CMT Public Id: 22300219FD2E00495D899ABF18A7C957C535F2BD
Preparing bootstrap to use USB BootMedia
Sending RAW 2ND
Initializing...
Initialization error
Old 11-18-2012, 13:11   #296 (permalink)
piracik's Avatar
Member: 133762
Reading phone info
MCU SW Version:
V 07.10
25-03-10
RM-638
(c) Nokia
PPM Version:
V 07.10
25-03-10
RM-638
(c) Nokia
OC
Content: orange UK
V 07.10
25-03-10
RM-638
(c) Nokia
Simlock status:
Block 1:
Block 2:
Reading phone data
Sending RAW 2ND
Initializing...
Try via Fbus USB not supported... !
The Following 2 Users Say Thank You to piracik For This Useful Post:
Old 12-23-2012, 16:22   #297 (permalink)
Member: 1841629
request
* slapwith support for new oclhashcat, atleast v0.10
* separate calculator for nck from masterkey (simply the ability to skip using slap)
* ability to read multiple phones to log directly, and then expect a new phone to be read
* multiple unlock-calculators in ONE application for huawei, alcatel, blackberry etc.
* quick link to ftdi drivers on website or in the application.
* ONE place for ALL downloads on fenix-key website. diferent urls for some downloads only make confused and frustrated users.
bug/error reports
* slap outdated, soluton = see request
* fenix-key is missing after reboot (win7/x64)
* forum and other links in the main application are dead/not working
* fenix reader servicetool, hangs and dies when clicking around in the application
* your website links to "gsm24forum" and that link is dead also..
Last but not least, thanks for listening
Last edited by morelikeyou; 12-23-2012 at 16:31. Reason: Added some suggestions and error reports
Old 03-01-2013, 18:47   #298 (permalink)
Member: 1868823
can t register fenixkey , stuck on registering and nothing hapening last time i tride lat 2 hours ,pls help
Old 03-09-2013, 17:29   #299 (permalink)
Member: 1527737
Sonork: 100.1606991
I need oclHashcat-lite-0.06 pleas help
Thanks
Phone Stuff for FREE & KEy-GEn For Logo Editor ! BoNtEk - ThA WtC MeMbA Nokia Multimedia 10 03-11-2013 15:27
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
Upload & Download Eprom Lousangeles Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 09-16-2011 13:43
Nokia 5110 & 6110 Schemics MyKy Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 2 08-06-1999 08:36
i can unlock nokia 51xx/61xx sp locks 1,2,3,4 £40 each £30 bulk for u.k only spterminator Main Sales Section 0 08-01-1999 05:46
Page generated in 0.59399 seconds with 12 queries
