04-29-2011, 10:01 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: Madrid
Member: 205178 Status: Offline Thanks Meter: 18 | HD6990 Temperature Control?!?!?! Any program or method to down the temperature.... Thanks BR |
04-29-2011, 12:32 | #3 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
You got bad CASE just buy good cooled and your problem gone need buy something like this Hot News - Cooler Master Debuts High Air Flow Premium Chassis - Cooler Master - Leading Provider of Computer Case | Cooler | Power Supply for 100-150 euro not for 20-30 euro case !! !! | |
04-29-2011, 12:42 | #6 (permalink) |
Member: 205178 Status: Offline Thanks Meter: 18 | No overclocked and i have a good case Zalman, the case its open to cool better. I think the problem is speed fun...with other pc with MXkey sw, i have 75ºC becouse i can open the MSI afterburnner and control the fans... Any program to config this... Thanks |
04-29-2011, 14:40 | #8 (permalink) |
No Life Poster Join Date: Mar 2005 Location: cebu city
Member: 126086 Status: Offline Sonork: 100.113901 Thanks Meter: 232 | My video card is running at XX degrees Celcius! Is this bad?! Not at all. Graphics cards these days are rated to around 100C! For instance, people who fold or game heavily could see their GPU(s) reach upwards of 90C. This is normal, they can withstand the heat - it's like apples and oranges compared to CPUs, where 75C is the danger-zone these days. Don't panic! I'm still really uncomfortable running my card(s) over XX Celcius! If you're really worried about temps over say 65-70C, you could turn your fan up to 100% on your card. If that still isn't good enough, well, you could always watercool it or buy an aftermarket cooler. When should I be worried about temperatures? Most would tell you about 105C is the point-of-no-return. Realistically though, for everyday use, you should not exceed 95-98C for extended periods of time. How can I monitor my temperature on my GPU(s)? You could use apps such as CPUID's HWMonitor, and in addition you could use eVGA Precision to monitor your temps as well. Keep in mind though, these chips ARE rated to run at these temperatures! If you're running below 90C the majority of the time, don't panic! |
05-01-2011, 23:36 | #11 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | i'm running about 80 celsius and all is ok. more than a week without stopping , stiil works anyone knows a software who tells how many watts is the pc using??? not only the GPU's but the total??? regards |
05-12-2011, 07:30 | #12 (permalink) | |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | Quote:
B.R. Alkapone | |
06-02-2011, 14:30 | #13 (permalink) |
Freak Poster Join Date: Mar 2004 Age: 58
Member: 57959 Status: Offline Thanks Meter: 7 | [QUOTE=Alkapone;7307122]There is no such software, but there is separate device for that, and they are cheap. B.R. Alkapone[/QUO WILL U GIVE THE DETAIL OF THAT DEVICES . |
Cellphone-Controlled-Devices | Ice Dragon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-30-2001 12:10 |
New Tau controller | chemist | Motorola Old Legacy (EMMI) | 0 | 11-02-2001 08:34 |
SL45: control-block Not Valid?! | X-Santo | x1x to x45/x50 | 0 | 10-31-2001 06:49 |
Pc-local can control 3210? | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-25-2000 02:25 |
How can I use AT command control Nokia6110?Help me! | arnom | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 07-15-2000 07:35 |
