05-05-2011, 20:00 | #1 (permalink) |
No Life Poster Join Date: Aug 2009 Location: Future Age: 30
Member: 1093004 Status: Offline Thanks Meter: 4,382 | nokia 5130 error PLEASE PRESS PHONE`S POWER BUTTON Extracting loaders from flash file Sending 2ND Sending Algo Sending Pasubtoc Reconnecting Loader is not responding Job's finished with errors! i have flashed previous and i n the middle of flash stopped and now phone is dead |
05-05-2011, 22:57 | #2 (permalink) | |
No Life Poster Join Date: Jun 2009 Location: SouthAmericaUnlockers Age: 52
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | 5130 c2 Quote:
Charge the Batery full Choice to LATEST Flash Press Flah in Usb dead Press a litlle Power On Button and wait 1 Minute B/R The_Polack | |
05-06-2011, 18:42 | #9 (permalink) |
Crazy Poster Join Date: Aug 2010
Member: 1370284 Status: Offline Thanks Meter: 11 | Do it by usb, and is tested to 100%. No phone found. Connect your phone using USB cable and try again. Checking connection... Reading phone info Product type: RM-495 MCU SW Version: V 05.80 18-12-08 RM-495 (c) Nokia PPM Version: V 05.80 18-12-08 RM-495 (c) Nokia UA Imei: 353223036890078 Product code: 0580923 Simlock status: Profile bits: 8000000000000000 Config key: 7223100000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 72 23 10 Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 74 81 0F Block 3: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 74 40 2F Looking for flash files Flash files found for selected product Job's finished successfully! Checking connection... Reading phone info Product type: RM-495 MCU SW Version: V 05.80 18-12-08 RM-495 (c) Nokia PPM Version: V 05.80 18-12-08 RM-495 (c) Nokia UA Imei: 353223036890078 Product code: 0580923 Simlock status: Profile bits: 8000000000000000 Config key: 7223100000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 72 23 10 Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 74 81 0F Block 3: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 74 40 2F Looking for flash files Flash files found for selected product Job's finished successfully! Checking connection... Reading phone info Product type: RM-495 MCU SW Version: V 05.80 18-12-08 RM-495 (c) Nokia PPM Version: V 05.80 18-12-08 RM-495 (c) Nokia UA Imei: 353223036890078 Product code: 0580923 Simlock status: Profile bits: 8000000000000000 Config key: 7223100000000000 Fbus codes typed: 0 Key codes typed: 0 Block 1: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 72 23 10 Block 2: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 74 81 0F Block 3: Lock 1: CLOSED(IMSI); TYPE: 5; DATA: 74 40 2F Looking for flash files Flash files found for selected product Job's finished successfully! Flashing started PLEASE PRESS PHONE`S POWER BUTTON Extracting loaders from flash file Sending 2ND Sending Algo Sending Pasubtoc Reconnecting Loader is alive! Checking software version Erasing MCUSW Flash area Erasing CMT area 00000000 - 000006BF Erasing CMT area 000006C0 - 0001FFFF Erasing CMT area 00040000 - 000BFFFF Erasing CMT area 000C0000 - 0013FFFF Erasing CMT area 00140000 - 0137FFFF Erasing CMT area 01380000 - 0151FFFF Erasing PPM Flash area Erasing CMT area 01520000 - 01DBFFFF Erasing CNT Flash area Erasing CMT area 01DC0000 - 0215FFFF Erasing CMT area 02160000 - 03FBFFFF Flashing MCUSW Sending NOLO Sending KEYS Sending PRIMAPP Sending PASUBTOC Sending PAPUBKEYS Sending UPDAPP Sending DSP0 Sending MCUSW Short delay between flash files Flashing PPM Short delay between flash files Flashing CNT Finishing loader session... Switching on device.. Doing post - flashing procedures Setting defaults: Set Factory Setting product code: 0580923 Setting NORMAL MODE Job's finished successfully! Greetings |
05-06-2011, 18:57 | #10 (permalink) | |
Member: 1093004 Status: Offline Thanks Meter: 4,382 | Quote:
Flashing started PLEASE PRESS PHONE`S POWER BUTTON Extracting loaders from flash file Sending 2ND Sending Algo Sending Pasubtoc Reconnecting Loader is not responding Job's finished with errors! same error | |
05-06-2011, 19:16 | #11 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: UK Age: 41
Member: 922305 Status: Offline Sonork: 100.1580089 Thanks Meter: 8,995 | Quote:
BR, Lavarow | |
05-06-2011, 20:59 | #13 (permalink) |
Member: 922305 Status: Offline Sonork: 100.1580089 Thanks Meter: 8,995 | Personally, I met several times with the situation when the phone was ok and after a flash turned out that the phone has a problem with the HW. You can see many posts with successfuly flashing this phone. BR, Lavarow |
05-07-2011, 01:24 | #14 (permalink) |
Member: 1057178 Status: Offline Sonork: Kfe~Labs Co.- Thanks Meter: 568 | Read mi First Post This is a Cel Phone Super Tested. Charge the Batery full Choice to LATEST Flash Press Flah in Usb dead Press a litlle Power On Button and wait 1 Minute B/R The_Polack |
