Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Fenix Key
Old 03-16-2012, 11:18   #1 (permalink)
atoxpert's Avatar
Member: 762728
Sonork: 100.1587901
Thumbs up Nokia ASHA 303 succesfully flash by Fenix Key USB MODE!!
maybe im the BETA TEST flasher of this phone
this phone not recognize in Fenix software or
Unknown device
challenge accepted
[IMG]http://i3.*******cdn.com/resize/*******_images/-1/lens18278982_1312560700challenge-accepted.png[/IMG]
ok
For safety
backup first
PM and RPL via USB
start flashing with the same product code
Software version: 1.2.1
Detected card sn: 7176F331B01A
Card version: 01.00
Life counter: 96.82%
Fenix Reader SW version: 0.0.2
Connection interface is set to USB now.
Checking connection...
Reading phone info
Product type: RM-763
MCU SW Version:
V 13.44
04-11-11
RM-763
(c) Nokia
PPM Version:
V 13.44
04-11-11
RM-763
(c) Nokia
T
Imei: 358279040945006
Product code: 059J1L6
Simlock status:
Profile bits: 0000000000000000
Config key: 2440700000000000
Fbus codes typed: 0/10
Key codes typed: 0/3
Block 1:
Lock 1: OPEN(IMSI); TYPE: 5; DATA: FF FF FF
Lock 2: OPEN(GID1); TYPE: 1; DATA: FF FF
Lock 3: OPEN(GID2); TYPE: 1; DATA: FF FF
Lock 4: OPEN(IMSI); TYPE: 5; DATA: FF FF FF FF FF FF FF FF
Lock 5: OPEN(IMSI); TYPE: 5; DATA: FF FF FF FF FF FF FF FF
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Analyzing profile bits...
This phone can be unlocked via keyboard and fbus
Looking for flash files
Flash files found for selected product
Job's finished successfully!
Flashing started
Battery voltage: 4093mV
Reading important PM fields
Checking connection
Field received. ID = 120
Field received. ID = 308
PM backup saved as: C:\Documents and Settings\YURI\My Documents\Lavarow\Fenix\Backup\Pm\358279040945006-3-16-2012 5-38-46 PM.pm
CMT Flash: Unknown vendor - Unknown product
Setting flash mode
CMT Hash : 3AB5DB70B45D23F1ADEEBB5734160706
CMT Hw ID: 400C192103032108
CMT Boot ROM CRC: 2CAC45E2
CMT Secure ROM CRC: 3BC33C8B
CMT Public Id: 0C2F0000FFFB3C40DC219D0C486854F5CD6AB919
CMT Papubkeys: A4FE3A0330FE3A0320775F021B10006F
Preparing *****trap to use USB BootMedia
Sending RAW 2ND
Sending RAW ALGO
Reconnecting
Loader is alive!
Reading certificates
Reading CMT certificates
Reading NPC
Saving NPC
Reading VARIANT
VARIANT is empty
Reading CCC
Saving CCC
Reading HWC
Saving HWC
Certificates saved as: C:\Documents and Settings\YURI\My Documents\Lavarow\Fenix\Backup\Certs\3-16-2012 5-39-11 PM000000030000022600010007400C192103032108-3-16-2012 5-39-11 PM.rpl
Checking software version
Partitioning file: rm763__13.44.mcusw
Partitioning file: rm763__13.44.ppm_t
Partitioning file: rm763__13.44.image_t_059J1L6_005
Erasing MCUSW Flash area
Erasing CMT area 00040000 - 000403FF
Erasing CMT area 000C0000 - 0013FFFF
Erasing CMT area 00140000 - 004BFFFF
Erasing CMT area 004C0000 - 0073FFFF
Erasing CMT area 00740000 - 0147FFFF
Erasing CMT area 00160000 - 0017FFFF
Erasing CMT area 03300000 - 0397FFFF
Erasing CMT area 0F080000 - 0F67FFFF
Erasing CMT area 01480000 - 0253FFFF
Erasing CMT area 02540000 - 026BFFFF
Erasing CMT partition
Erasing PPM Flash area
Erasing CMT area 026C0000 - 032FFFFF
Erasing CNT Flash area
Erasing CMT area 03980000 - 0F07FFFF
Flashing MCUSW
Sending KEYS
Sending DSP0
Sending MCUSW
Sending MCUSW1
Sending GENIO_INIT
Sending ISA+DYNSW
Sending ADA
Sending PRIMAPP
Sending PASUBTOC
Sending RAP3NAND
Sending UPDAPP
Sending ISA+EXTDRV
Short delay between flash files
Flashing PPM
Flashing CNT
Finishing loader session...
Device communication timeout occurred
Job's finished with errors!
Reading phone info
MCU SW Version:
V 13.44
04-11-11
RM-763
(c) Nokia
PPM Version:
V 13.44
04-11-11
RM-763
(c) Nokia
T
Content Pack Version:
Content: t_059J1L6
V 13.44
04-11-11
RM-763
(c) Nokia
Imei: 12345610654321?
Simlock status:
Config key: 0000000000000000
OH NO!!!!!!!!!!!!!!1
IMEI corrupted!!!!!! and it become contact service
Sh*T happens
but im not surrender yet
flash it again with DEAD USB FLASH
and automatically fenix soft will also write the back up
No phone found. Connect your phone using USB cable and try again.
Access violation at address 00410A8A in module 'fenix.exe'. Write of address 0000000C
PLEASE PRESS PHONE`S POWER BUTTON
Sending RAW 2ND
Initializing...
Trying to set test mode automatically...
Please disconnect phone from computer, remove the battery, put it back, switch the phone on and connect it to the computer.
Disconnected from the device
Waiting for phone...
Aborting job... Software will abort the job as soon as possible and it might take a while.
Job has been aborted by user!
Sending RAW 2ND
Initializing...
Flashing started
Sending RAW 2ND
Sending RAW ALGO
Reconnecting
Loader is alive!
Reading NPC
Saving NPC
Reading VARIANT
VARIANT is empty
Reading CCC
Saving CCC
Reading HWC
Saving HWC
Certificates saved as: C:\Documents and Settings\YURI\My Documents\Lavarow\Fenix\Backup\Certs\3-16-2012 5-52-12 PM000000030000022600010007400C192103032108-3-16-2012 5-52-12 PM.rpl
Flashing MCUSW
Sending KEYS
MCU PAPUBKEYS are missing, sending first available block
Sending PAPUBKEYS
Sending DSP0
Sending MCUSW
Sending MCUSW1
Sending GENIO_INIT
Sending ISA+DYNSW
Sending ADA
Sending PRIMAPP
Sending PASUBTOC
Sending RAP3NAND
Sending UPDAPP
Sending ISA+EXTDRV
Flashing PPM
Flashing CNT
Switching on device..
Doing post - flashing procedures
Setting defaults: Set Factory
Setting product code: 059J1L6
Setting NORMAL MODE
Reading phone info
MCU SW Version:
V 13.44
04-11-11
RM-763
(c) Nokia
PPM Version:
V 13.44
04-11-11
RM-763
(c) Nokia
T
Content: t_059J1L6
V 13.44
04-11-11
RM-763
(c) Nokia
Simlock status:
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
DONE
br
ATO
The Following 4 Users Say Thank You to atoxpert For This Useful Post:
Old 03-16-2012, 18:46   #2 (permalink)
matcom gsm's Avatar
Member: 106346
Sonork: 100.1577684
nice info bro thanks for good work we make this good work a stick in sticky area
br
matcom gsm
The Following 2 Users Say Thank You to matcom gsm For This Useful Post:
Old 03-17-2012, 02:13   #3 (permalink)
Member: 1577126
Sonork: ::::::
nice info bro thanks for good work .....
Br.
The Following User Says Thank You to Dj trungZZ For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
Page generated in 0.26562 seconds with 11 queries
