The_Gorr | 02-04-2012 13:21 | PolarFIS CAN Reader (Sniffing tool) http://www.auto-polar.com/images/Polar_CAN_Reader.png PolarFIS CAN Reader image (Sniffing tool) : Direct link (descarga) Instructions manual (in english) : Direct link (descarga)
Hi to all, PolarFIS Can reader is a software that allows you to "sniff" all part of communication of your vehicle with one unit of Polar FIS+ or FIS+ Advanced.
This data is very important for development of all our products and helps us to improve it step by step. This software allows :- Give better support to end user (final customer) more easily and effective
- Increase at max. recopilation for all kind of vehicles
- Upgrade FIS products with non-supported configurations
- Solve problems more quick (decrease time)
If you have one vehicle with any of our products PolarFIS [PF02 y PF03], and you face any problem or non-working function, please use it for dump part of communication and help us to improve and fix quickly your problem. You only must select option that you desire to "sniff", and start the process (very easy) Infortainment. In this mode, all data related to the communication between the box and the FIS will be logged. This mode is indicated for issues related to menu crashes, battery drain, etc.] - Motor: In this mode, all data related to the communication with the engine ECU will be saved. This mode is indicated for problems with parameter reading.
- Diagnostics: Al data related with the diagnostics communication will be saved. Indicated for problems obtaining the Bordnetz or Comfort ECUs reference or coding functions such rain or light sensor modification, DRLfs, etc.
- Blinkers: Save all data related with the Blinkers. Indicated for issues with blinker lights.
- Mirrors: Save data related with the mirror lowering function of Polar FIS. Indicated for issues with that function.
- Parktronic: Save data related with the Parktronic OPS emulation function of Polar FIS. Indicated for issues with that function.
- Processor A: Special mode not commonly used, new instructions will be provided in case that it will be necessary to use.
- Processor B: Special mode not commonly used, new instructions will be provided in case that it will be necessary to use.
If this is the case, please contact us with any of our "Supporters" in forum and we will tell you how to send us file dumped.
Inside ZIP it comes 2 complete manuals (in spanish and english)
Any other thing, not doubt in contact us.
With best regards, [ \W3nd|g0 ] Http://www.Auto-Polar.com |
