10-03-2002, 18:48 | #7 (permalink) |
No Life Poster Join Date: Dec 2000 Location: gsmdoctor.pl Age: 48
Member: 2755 Status: Offline Thanks Meter: 42 | Here you are ... *5806 - view fw. * # 06 # View IMEI * # 0044 # English * # 0049 # Deutsch hold * 4329 Net Monitor1 hold * 621342 Net Monitor2 hold * 5472 M4 Testmode hold * 5806 SW version hold * 5807 HW version hold * 936505 SW and HW version hold * 476989 NS Lock Menu hold * 482896 CP Lock Menu hold * 574243 NS Lock Menu hold * 967678 SP Lock Menu hold * 362628 IMSI Lock Menu hold * 787090 Lock net.level hold * 787292 Lock net.level hold * 3926 Shut Down... |
10-21-2002, 20:33 | #9 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Ireland Age: 54
Member: 10516 Status: Offline Thanks Meter: 1 | Hello, I have eclipse with "Enter lock code" I tried MitsWorkshop , select Mars and pres reed code: I get LOCK UNLOCK NET : 01010101 : 02020202 SUBNET : 03030303 : 04040404 IMSI : 09090909 : 00000000 CORP : 07070707 : 08080808 PROV : 05050505 : 06060606 EXT : 07070707 : 08080808 Please, where is my code? Best regards Andrews |
10-25-2002, 17:08 | #11 (permalink) |
Freak Poster Join Date: Aug 2002 Location: iasi, Romania Age: 49
Member: 14258 Status: Offline Thanks Meter: 3 | Use MsTools 2000.In DOS mode m4showlock.exe > code.txt Afther that you have generated file with all codes.Speed comunication must be 38400(in tmpc_conf.ini).100% working Best regards Marian. |
10-29-2002, 12:26 | #12 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Hello mariangsm So, by your solution I get Codes, but where is User Code? 1 file(s) copied Copying tmpc_conf_M5.ini -> tmpc_conf.ini Starting TestMode. IMEI = 3507033400259400-00 -------------------------------------------------------------------------------- MccMncNum = 0 -------------------------------------------------------------------------------- ImsiNum = 0 -------------------------------------------------------------------------------- ProtectFlashLock: Status = 0x3067 = LOCK_ON -------------------------------------------------------------------------------- PermLock: Status = 0x2468 = LOCK_OFF -------------------------------------------------------------------------------- NetLock: Status = 0x2468 = LOCK_OFF NetLock: NbTry = 10 NetLock: LockCode = 01010101 NetLock: UnLockCode = 02020202 -------------------------------------------------------------------------------- ImsiLock: Status = 0x2468 = LOCK_OFF ImsiLock: NbTry = 10 ImsiLock: LockCode = 09090909 ImsiLock: UnLockCode = 00000000 -------------------------------------------------------------------------------- NetSubLock: Status = 0x2468 = LOCK_OFF NetSubLock: NbTry = 10 NetSubLock: LockCode = 03030303 NetSubLock: UnLockCode = 04040404 NetSubLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 NetSubLock: DataLockLen = 0 -------------------------------------------------------------------------------- CorpLock: Status = 0x2468 = LOCK_OFF CorpLock: NbTry = 10 CorpLock: LockCode = 07070707 CorpLock: UnLockCode = 08080808 CorpLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 CorpLock: DataLockLen = 0 -------------------------------------------------------------------------------- ServProvLock: Status = 0x2468 = LOCK_OFF ServProvLock: NbTry = 10 ServProvLock: LockCode = 05050505 ServProvLock: UnLockCode = 06060606 ServProvLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ServProvLock: DataLockLen = 0 -------------------------------------------------------------------------------- ExtLock: Status = 0x2468 = LOCK_OFF ExtLock: NbTry = 5 ExtLock: LockCode = 07070707 ExtLock: UnLockCode = 08080808 ExtLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ExtLock: DataLockLen = 0 -------------------------------------------------------------------------------- DataArea#1: 0x3D 0xF7 0x6D 0xE5 0x76 0x7F 0xFE 0x6D DataArea#2: 0x3D 0xF7 0x6D 0xE5 0x76 0x7F 0xFE 0x6D DataArea#3: 0x3D 0xF7 0x6D 0xE5 0x76 0x7F 0xFE 0x6D -------------------------------------------------------------------------------- Stoping TestMode. Best Regards Andrews |
10-30-2002, 12:46 | #13 (permalink) |
Member: 14258 Status: Offline Thanks Meter: 3 | You have error in reding or new version sw in phone. Normal you must have something like this....... 1 file(s) copied Copying tmpc_conf_M4.ini -> tmpc_conf.ini Starting TestMode. IMEI = 3507033570048200-00 -------------------------------------------------------------------------------- MccMncNum = 1 Net1: 260-02 -------------------------------------------------------------------------------- ImsiNum = 0 -------------------------------------------------------------------------------- ProtectFlashLock: Status = 0x3067 = LOCK_ON -------------------------------------------------------------------------------- PermLock: Status = 0x2468 = LOCK_OFF -------------------------------------------------------------------------------- NetLock: Status = 0x3067 = LOCK_ON NetLock: NbTry = 10 NetLock: LockCode = 48635674 NetLock: UnLockCode = 91042009 -------------------------------------------------------------------------------- ImsiLock: Status = 0x2468 = LOCK_OFF ImsiLock: NbTry = 10 ImsiLock: LockCode = 56424058 ImsiLock: UnLockCode = 79191482 -------------------------------------------------------------------------------- NetSubLock: Status = 0x2468 = LOCK_OFF NetSubLock: NbTry = 10 NetSubLock: LockCode = 64503432 NetSubLock: UnLockCode = 97970866 NetSubLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 NetSubLock: DataLockLen = 0 -------------------------------------------------------------------------------- CorpLock: Status = 0x2468 = LOCK_OFF CorpLock: NbTry = 10 CorpLock: LockCode = 20557390 CorpLock: UnLockCode = 13147624 CorpLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 CorpLock: DataLockLen = 0 -------------------------------------------------------------------------------- ServProvLock: Status = 0x2468 = LOCK_OFF ServProvLock: NbTry = 10 ServProvLock: LockCode = 32791816 ServProvLock: UnLockCode = 05969240 ServProvLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ServProvLock: DataLockLen = 0 -------------------------------------------------------------------------------- ExtLock: Status = 0x2468 = LOCK_OFF ExtLock: NbTry = 5 ExtLock: LockCode = 20557390 ExtLock: UnLockCode = 13147624 ExtLock: DataLock = 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 ExtLock: DataLockLen = 0 -------------------------------------------------------------------------------- DataArea#1: 0x6E 0xF7 0xEF 0x5C 0xEF 0xF3 0xDF 0x56 DataArea#2: 0x6E 0xF7 0xEF 0x5C 0xEF 0xF3 0xDF 0x56 DataArea#3: 0x6E 0xF7 0xEF 0x5C 0xEF 0xF3 0xDF 0x56 -------------------------------------------------------------------------------- Stoping TestMode. Regards Marian. |
To Furios Tm How To Unlock Mitsubishi M342i? | ..::khaled::.. | FuriousGold | 11 | 01-15-2009 16:49 |
How to unlock Mitsubishi Neptune | spinner | Mitsubishi | 0 | 09-24-2001 16:09 |
How to unlock mitsubishi mt-35 | markaba | Mitsubishi | 0 | 05-09-2001 23:54 |
How to unlock Mitsubishi Trium Galaxy ? | scum | Mitsubishi | 3 | 02-22-2001 13:59 |
How to unlock Mitsubishi MT20 | Dmitri | Various | 1 | 07-21-2000 12:25 |
