10-15-2001, 19:51 | #1 (permalink) |
Freak Poster Join Date: May 2001 Location: INDIA Age: 51
Member: 4491 Status: Offline Thanks Meter: 4 | mars dead but charging light on if charging |
10-15-2001, 20:28 | #2 (permalink) |
Freak Poster Join Date: Dec 2000
Member: 2797 Status: Offline Thanks Meter: 0 | Under loader put uniloader, under product put none(dont change nothing it will be ok),use your mars.bin and start download. When you put flasher cable on the phone phone must not power up , only led will light up red, and when you start download red changes to green and flashes.Some people say they do it without batery ,but I did it with and without batery.If after flashing phone says permenantly blocked or contact provider you need to write eeprom with troky reader/writer. regards<br />me@n |
10-15-2001, 20:58 | #4 (permalink) |
No Life Poster Join Date: Mar 2001 Location: Ukraine,Kiev Age: 48
Member: 3529 Status: Offline Thanks Meter: 1 | Hi! I mean its not flash problem.You can flash it many times and phone alive but after some times is dead again. I,m have similar phones 2 and some time its workimg but some time its dead.<br />PS. If disconnect battery (after cloning) when phone switch On and put it back you have similar problem - phone charging but dont switch On.<br />Regards.<br />Peter. |
10-15-2001, 22:54 | #5 (permalink) |
Member: 4491 Status: Offline Thanks Meter: 4 | Under loader put uniloader, under product put none(dont change nothing it will be ok),use your mars.bin and start download. When you put flasher cable on the phone phone must not power up , only led will light up red, and when you start download red changes to green and flashes.Some people say they do it without batery ,but I did it with and without batery.If after flashing phone says permenantly blocked or contact provider you need to write eeprom with troky reader/writer.<br />regards<br />me@n --------------------------------------------------<br />hello me@n after flashing 1 phone displayed con.prov.and uplode with marse.bin now phone is ok .but other 2 phone have same problem i don't know why ?? (only led light up red, and when i start download red changes to green and flashes)u or any one help me to out of this problem??<br />thanks for all <img src="wink.gif" border="0"> <br />To peter, friend i think u just chang small nicd battry on bord then clon uer phone .its work 90%<br />vivek <img src="smile.gif" border="0"> [ 16 October 2001: Message edited by: VIVEK ]</p> |
10-17-2001, 19:08 | #7 (permalink) |
Member: 2797 Status: Offline Thanks Meter: 0 | Viviek when you where trying to upload eeprom to 2. other phones did soft count from 1-16?<br />If not only thing you need to do is to upload eeprom again and when it counts from 1-16 it will be allright. regards |
E51 dead.. but fron light comes on.. need help | bakhshalvi007 | Nokia Hardware & Hardware Repair | 2 | 11-04-2009 06:51 |
6630 dead but only light on | gsm_oman | Nokia Hardware & Hardware Repair | 4 | 02-12-2009 15:37 |
V220 dead - but screen lights when putting in charger without battery | James_S | Motorola P2k | 3 | 10-29-2005 20:44 |
Mars dead only read light with charger | gilsie | Mitsubishi | 1 | 04-10-2003 15:42 |
7650 dead but gives light | Mr.Fl@sher | WD2 & APE (Symbian Phones) | 1 | 01-22-2003 07:38 |
