09-15-2002, 22:54 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Ireland Age: 54
Member: 10516 Status: Offline Thanks Meter: 1 | MSTools2000 ????? I download MSTools2000 about 12 Mbyte, Instal till 2step, 3step I cancell. Copy crack-msts to exec dir in ms tools and run it. And I get message: can't open file MSTOOL~1.EXE can't open file MSTOOL~2.EXE Need your Help. Regards Andrews |
09-16-2002, 04:54 | #2 (permalink) |
Freak Poster Join Date: Apr 2002 Location: CDMA World Age: 64
Member: 10966 Status: Offline Thanks Meter: 1 | Step by step operation: Hi. I should to do full instalation of MS Tools2000. Then copy 2 files:megacrk.exe and mstools2000.crk to the C:\MSTools_2000\ApplicationFiles\Exec. Then go to the Dos mode and make command lineкомандная строка) megacrk.exe mstools2000.crk and run it. You get patch. After that the line :Reset "Permanent lock indicator" will be visibled. That's All. Enjoy. |
09-16-2002, 08:20 | #3 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Thanks ZenerDiode I have only crack-mstl.exe and where I can find megacrack. And in your answer I can't read this text command lineкомандная строка) Thanks Best Regards Andrews |
09-16-2002, 09:25 | #4 (permalink) |
Member: 10966 Status: Offline Thanks Meter: 1 | Download these files from here: http://www.megasoft.org.ua/msutils/f...000-1.7-M5.rar http://www.megasoft.org.ua/msutils/f...000-1.7-M4.rar Needing files you can find inside in DOC directory. Unreadable line - just command line: Regards. |
09-16-2002, 11:39 | #5 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Thanks ZenerDiode, Please let me know about this comand line, because I'm not to big PC specialist, and If possible can you step by step explane me what need to do with this comand line and where is this line? Go to Dos mode- this is need restart PC in MS-Dos mode? My windows is 98 Best Regards Andrews |
09-16-2002, 12:12 | #6 (permalink) |
Member: 10966 Status: Offline Thanks Meter: 1 | OK. Make some xxx.bat file. Example: 123.bat Using Notepad,insert to this file command line: megacrk.exe mstools2000.crk Then copy 123.bat file to C:\MSTools_2000\ApplicationFiles\Exec and run it. Then push "1" Then push "2" Then push "0" Then relax. Regards |
09-16-2002, 14:11 | #8 (permalink) |
Member: 10516 Status: Offline Thanks Meter: 1 | Hello ZenerDiode I make 123.bin and with Notepad in this file I write: megacrk.exe mstools2000.crk late I run this file , and get this message: C:\MSTools_2000\ApplicationFiles\Exec>megacrk.exe mstools2000.crk MEGASOFT 1999 - MEGACRACK - Based on Corner Cracker for MeSeDos version 0.1.6 for Win32 Crack : MSTools2000 (VER 001-00) - Trium mobile phones service suite. 1 - M4 version. Unlock 'Reset permanent lock' feature. - MSTools_2000_M4.exe 2 - M5 version. Unlock 'Reset permanent lock' feature. - MSTools_2000_M5.exe 0 - quit ? > 1 (C)rack | (U)ndo ? >c Unable to open MSTools_2000_M4.exe for writing !!! Crack : MSTools2000 (VER 001-00) - Trium mobile phones service suite. 1 - M4 version. Unlock 'Reset permanent lock' feature. - MSTools_2000_M4.exe 2 - M5 version. Unlock 'Reset permanent lock' feature. - MSTools_2000_M5.exe 0 - quit megacrk.exe mstools2000.crk megacrk.exe mstools2000.crk Where I make mistake? Best Regards Andrews |
09-17-2002, 04:08 | #10 (permalink) |
Member: 10966 Status: Offline Thanks Meter: 1 | To nawikre See carefully old topics couple days ago. --------------- To andrews If you main instalation was correct and all files(megacrk.exe,mstools2000.crk,MSTools_2000_M4. exe, MSTools_2000_M5.exe) were located in C:\MSTools_2000\ApplicationFiles\Exec directory,you should not have anyone problem. Check properties MSTools_2000_M4/M5.exe.(Right button of mouse)These files do not have "Read Only" click.If all's OK,try to reinstall SW and repeat all actions. Regards |
07-15-2003, 17:23 | #12 (permalink) | |
Junior Member Join Date: Jul 2003 Location: Yugoslavia Age: 39
Member: 34431 Status: Offline Thanks Meter: 0 | Quote:
Thanx! | |
07-15-2003, 17:34 | #14 (permalink) | |
mstools2000 install problems ?????? | PTR999 | Mitsubishi | 5 | 04-17-2002 23:00 |
mstools2000 | PTR999 | Mitsubishi | 0 | 04-09-2002 10:03 |
Need Mstools2000 and troky eprom writer | ren777 | Mitsubishi | 2 | 02-19-2002 19:38 |
crack for mstools2000 | crazybyte | Mitsubishi | 0 | 06-08-2001 02:04 |
Help for MsTools2000 -I need. | saveli | Mitsubishi | 3 | 05-28-2001 11:44 |
