Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Mitsubishi
Old 09-13-2005, 20:35   #1 (permalink)
MTi-GsM's Avatar
Member: 149389
wath's solution for this crasy m341i
this f***ing phone write connected with evolver 4.3 but when i clic chow code hi give unlock code 90909090
any solution please
i have 2 original cable m330
regard
Old 09-14-2005, 09:07   #2 (permalink)
balu_dark's Avatar
Member: 16251
remove cover from connector reverse it at 180 degree from usual position of m320
and plug connector with some force(phone must show - accessory connected)
Old 09-14-2005, 18:41   #3 (permalink)
MTi-GsM's Avatar
Member: 149389
@balu_dark: 10x . wat u have sayed i've tryed it befor doing this post,and i've this result with evolver 4.3:
unlock code : 90909090 ?????
PLZ any IDEA
Old 09-15-2005, 08:56   #4 (permalink)
balu_dark's Avatar
Member: 16251
if you see at plastic connector that you plug into phone
*....contacts.....* < need to remove this plastic detail!!!
must be :
*.contacts..*
after this fix you connector put more deep in phone connector hole if you have right cable after plug cable - phone must show string about connected acc.
E90. I need this solutions for this one... alwi7666 Mastertools 2 11-20-2009 18:42
UART = 1...solution for this? Big puzzle of this century....no ideas BIG coders? chatfan ODM (Original Design Manufacturing) 0 08-19-2009 18:48
To Chris922!! do you have a solution for this?.??? infogsm ARM9 BASED M62 / M62+ 22 07-28-2003 17:12
Regarding SAGEM Displaying EPPROM and switching OFF pls I want solution for this kelika7hills Infineon C16X M51 & ARM7 M52 BASED 4 05-05-2003 10:45
S_35 Solution for this version 07 padje x1x to x45/x50 1 11-14-2000 21:01
Page generated in 0.61231 seconds with 11 queries
