07-15-2013, 10:27 | #1 (permalink) |
Junior Member Join Date: Nov 2012 Location: southsudan
Member: 1839300 Status: Offline Sonork: southsudan Thanks Meter: 1 | flash file mq710 DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_EN71GL064 setting the Flash Parameters... Settings have been completed! Reading FileSystem info... Failed to read FS info. |
07-15-2013, 10:51 | #2 (permalink) |
Product Manager Join Date: Apr 2008 Location: Whitehole throught Blackhole!
Member: 747989 Status: Offline Sonork: 100.1593052 Thanks Meter: 8,621 | If you are requesting firmware of respective model, please post your request in the dragon sub forum: Dragon Flash Files - GSM-Forum BR Dipendra Pathak |
07-15-2013, 11:06 | #3 (permalink) |
Member: 1839300 Status: Offline Sonork: southsudan Thanks Meter: 1 | i need flash for this mobile model mQ710 dual sim Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=6 TXD=2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600701900006A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6600L7A Flash: NOR_EN71GL064 setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable Error: Failed to read ACK. |
