11-15-2013, 12:43 | #1 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1504491 Status: Offline Thanks Meter: 3 | need help for flash file wootel-P500 i need flash file. wootel-P500 android read log is :- >> Getting Mobile Connection Info... VCC Pin: GND Pin:5, Signal Pin:1, 2, 3, 4, >>> Scanning Mobile PinOut... >>> USB Pinfind No need Hold Mobile Power key... USB Pin Out: D+:3 D-:2 HardWare:VID:17_82 PID:4D_00 This is a Spreadtrun chip set... >>> Scanning Mobile USB Port... >>> Detecting COM PortCOM88 >>> Connecting Mobile... Mobile Connection Success... Mobile Firmware Version:SPRD3 >>> Downloading First Boot... >>> Mobile Info Project ID :Spreadtrum Boot Block version 1.1 >>> Downloading Second Boot... Baud Rate is Switched To:921600 Flash ID:000098BC Flash Size:20000000->512M Flash Name:NAND_TOSHIBATYBC0A111236KC10 CPU Name:6820/8810 All Done... hope reply from you. thanks |
11-18-2013, 06:32 | #2 (permalink) | |
Member: 1504491 Status: Offline Thanks Meter: 3 | Quote:
pls reply thanks | |
