Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 05-22-2020, 23:51   #1 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
Cool 1st World Wiko RIDGE FAB 4G changing DAMAGED eMMC from 16GB to 64GB
Got a handset with Damaged 16GB eMMC ( eMMC won't accept a flash by USB or ISP )
so my solution was try program new eMMC but with big storage 64GB
THIS IS ONLY IMPROVING THE POWER OF THE GIANT MEDUSA PRO
And here my steps
LOG WIKO eMMC INFO :
Welcome to Medusa Pro Software version 2.0.9.  Started.
 Reader #0: Alcor Micro USB Smart Card Reader 0
 Reader #1: Alcor Micro USB Smart Card Reader 1
 Reader #2: Alcor Micro USB Smart Card Reader 2
 Reader #3: Alcor Micro USB Smart Card Reader 3
 Loading firmware. Please wait...    Done.
 Selected eMMC interface.
 Selected BGA 221 socket.
 Please disconnect battery and USB cable.
 Model Settings:
 Interface : eMMC
 Voltage   : 2.8V
 Bus Mode  : 8 bits
 Bus speed : 50 MHz
 Connecting...
 Device       : Hynix eMMC HAG2e
 Page size    : 512 B
 Block size   : 512 B
 Block count  : 30785536
 Size         : 14.68 GB (15032.00 MB)
 CID Info
 CID                   : 90014A48414732650507DF06D0CE329B
 Manufacturer ID       : 0X90
 Device/BGA            : BGA (Discrete embedded)
 OEM/Application ID    : 0X4A
 Product name          : HAG2e
 Product revision      : 0.7
 Product serial number : (hex) DF06D0CE
 Manufacturing date    : 03/2015
 CSD Info
 CSD                   : D02701320F5903FFFFFFFFEF8A4040D3
 CSD structure         : CSD version No. 1.2
 SPEC version          : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
                         4.51, 5.0, 5.01, 5.1
 Data read access time1: 15 ms
 TRAN speed            : 26 MHz
 READ block length     : 512 Bytes
 WP group enable       : YES
 PERM_WRITE_PROTECT    : NO
 TMP_WRITE_PROTECT     : NO
 EXTCSD Info
 Revision 1.7 (for MMC v5.0, v5.01)
 Erase block size      : 512 Kbytes
 Boot1 size            : 4096 Kbytes
 Boot2 size            : 4096 Kbytes
 RPMB size             : 4096 Kbytes
 Partition config      : (0x38) 00111000
 Boot partition enable : User area
 (Bus width = 1Bit)
 Boot ACK              : No boot acknowledge sent (default)
 Boot bus conditions   : (0x00) 00000000
 Boot bus width        : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
 Reset boot bus conditions   : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
 Boot mode             : Use single data rate + backward compatible timings in boot operation (default)
 RST_n function        : (0x00) RST_n signal is temporary disabled (default)
 Partitioning support  : Device supports partitioning features
 Enhanced attribute    : Device can have enhanced technological features in partitions and user data area.
 Max enhanced data size: 7692288 Kbytes
 Partitions attribute  : 0x0
 Part setting completed: 0x0
 GP partition 1 size   : 0 b
 GP partition 2 size   : 0 b
 GP partition 3 size   : 0 b
 GP partition 4 size   : 0 b
 Enhanced area size    : (0x0) 0 b
 Enhanced area start   : (0x0) 0 b
 ---------------------------------------------------------------Searching Android build info...
 Ok
 Disk/Image size       : ab800000 bytes
 Device sector size    : 512 bytes
 Partition offset      : 461920
 Number of sectors     : 3325952
 Device Manufacturer   : WIKO
 Device Platform       : msm8916
 Build ID              : LRX22G
 Display Build ID      : LRX22G release-keys
 Release ID            : 5.0.2
 Device Model          : RIDGE FAB 4G
 Device Name           : l5320
 Architecture ABI      : armeabi-v7a
 Architecture ABI2     : armeabi
 Architecture ABI List : armeabi-v7a,armeabi
 Build Description     : l5320-user 5.0.2 LRX22G eng.android.20171227
 Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/HAG2e_22_05_2020_22_38_30.bin.
 Connect successful.
 SW: 2.0.9; FW: 2.00.
 P00: GPT              (00000000, 00020000)    64 MB
 P01: modem            (00020000, 00020000)    64 MB
 P02: sbl1             (00040000, 00000400)    512 KB
 P03: sbl1bak          (00040400, 00000400)    512 KB
 P04: aboot            (00040800, 00000800)    1024 KB
 P05: abootbak         (00041000, 00000800)    1024 KB
 P06: rpm              (00041800, 00000400)    512 KB
 P07: rpmbak           (00041C00, 00000400)    512 KB
 P08: tz               (00042000, 00000400)    512 KB
 P09: tzbak            (00042400, 00000400)    512 KB
 P10: hyp              (00042800, 00000400)    512 KB
 P11: hypbak           (00042C00, 00000400)    512 KB
 P12: pad              (00043000, 00000800)    1024 KB
 P13: modemst1         (00043800, 00000C00)    1536 KB
 P14: modemst2         (00044400, 00000C00)    1536 KB
 P15: misc             (00045000, 00000800)    1024 KB
 P16: fsc              (00045800, 00000002)    1024 b
 P17: ssd              (00045802, 00000010)    8 KB
 P18: splash           (00045812, 00005000)    10 MB
 P19: DDR              (00060000, 00000040)    32 KB
 P20: fsg              (00060040, 00000C00)    1536 KB
 P21: sec              (00060C40, 00000020)    16 KB
 P22: boot             (00060C60, 00010000)    32 MB
 P23: system           (00070C60, 0032C000)    1624 MB
 P24: persist          (0039CC60, 00010000)    32 MB
 P25: cache            (003ACC60, 00083000)    262 MB
 P26: recovery         (0042FC60, 00010000)    32 MB
 P27: keystore         (00440000, 00000400)    512 KB
 P28: config           (00440400, 00000040)    32 KB
 P29: oem              (00440440, 00020000)    64 MB
 P30: userdata         (00480000, 018DBFDF)    12.43 GB
 Backuping modemst1 partition...
 Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG2e_modemst1_0x43800_0xc00_22_05_2020_22_38_30.bin file...
 Reading. Please wait... Done.
 Elapsed time 00:00:00
 Backuping modemst2 partition...
 Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG2e_modemst2_0x44400_0xc00_22_05_2020_22_38_30.bin file...
 Backuping fsg partition...
 Opening C:/Program Files (x86)/Medusa Pro Software/Backups/HAG2e_fsg_0x60040_0xc00_22_05_2020_22_38_30.bin file...
 RPMB: Counter of the successful data write requests = 45.
LOG NEW eMMC FROM OPPO F1s :
 Model Settings:
 Interface : eMMC
 Voltage   : 2.8V
 Bus Mode  : 8 bits
 Bus speed : 50 MHz
 Connecting...
 Device       : Samsung eMMC RC14MB
 Page size    : 512 B
 Block size   : 512 B
 Block count  : 122142720
 Size         : 58.24 GB (59640.00 MB)
 CID Info
 CID                   : 150100524331344D42074E5CC6954341
 Manufacturer ID       : 0X15
 OEM/Application ID    : 0X00
 Product name          : RC14MB
 Product serial number : (hex) 4E5CC695
 Manufacturing date    : 04/2016
 CSD Info
 CSD                   : D02701320F5903FFF6DBFFEF8E40400D
 TRAN speed            : 26 MHz
 EXTCSD Info
 Revision 1.8 (for MMC v5.1)
 Partition config      : (0x48) 01001000
 Boot partition enable : Boot partition 1
 (Bus width = 1Bit)
 Boot ACK              : Boot acknowledge sent during boot operation Bit
 RST_n function        : (0x01) RST_n signal is permanently enabled
 Max enhanced data size: 30531584 Kbytes
 Ok
 Disk/Image size       : 8f800000 bytes
 Partition offset      : 540672
 Number of sectors     : 6291456
 Device Manufacturer   : OPPO
 Device Platform       : mt6750
 Build ID              : LMY47I
 Display Build ID      : A1601EX_11_A.33_170814
 Release ID            : A1601EX_11_A.33_170814
 Device Model          : A1601
 Device Name           : A1601
 Architecture ABI      : arm64-v8a
 Architecture ABI List : arm64-v8a,armeabi-v7a,armeabi
 Build Description     : full_oppo6750_15331-user 5.1 LMY47I 1502723706 release-keys
 Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RC14MB_22_05_2020_22_39_42.bin.
 Connect successful.
 P00: GPT              (00000000, 00000040)    32 KB
 P01: recovery         (00000040, 00008000)    16 MB
 P02: para             (00008040, 00000400)    512 KB
 P03: reserve1         (00008440, 00001000)    2048 KB
 P04: reserve2         (00009440, 00008000)    16 MB
 P05: reserve3         (00011440, 00001000)    2048 KB
 P06: reserve4         (00012440, 00008000)    16 MB
 P07: oppo_custom      (0001A440, 00000800)    1024 KB
 P08: expdb            (0001AC40, 00005000)    10 MB
 P09: frp              (0001FC40, 00000800)    1024 KB
 P10: nvdata           (00020440, 00010000)    32 MB
 P11: metadata         (00030440, 00010000)    32 MB
 P12: protect1         (00040440, 00004000)    8 MB
 P13: protect2         (00044440, 00007BC0)    15.47 MB
 P14: seccfg           (0004C000, 00004000)    8 MB
 P15: oemkeystore      (00050000, 00004000)    8 MB
 P16: proinfo          (00054000, 00001800)    3072 KB
 P17: md1img           (00055800, 0000C000)    24 MB
 P18: md1dsp           (00061800, 00002000)    4 MB
 P19: md1arm7          (00063800, 00001800)    3072 KB
 P20: md3img           (00065000, 00002800)    5 MB
 P21: nvram            (00067800, 00002800)    5 MB
 P22: lk               (0006A000, 00000800)    1024 KB
 P23: lk2              (0006A800, 00000800)    1024 KB
 P24: boot             (0006B000, 00008000)    16 MB
 P25: logo             (00073000, 00004000)    8 MB
 P26: tee1             (00077000, 00002800)    5 MB
 P27: tee2             (00079800, 00002800)    5 MB
 P28: secro            (0007C000, 00003000)    6 MB
 P29: keystore         (0007F000, 00004000)    8 MB
 P30: reserve_exp1     (00083000, 00001000)    2048 KB
 P31: system           (00084000, 00600000)    3072 MB
 P32: reserve_exp2     (00684000, 00002000)    4 MB
 P33: reserve_exp3     (00686000, 00002000)    4 MB
 P34: cache            (00688000, 00080000)    256 MB
 P35: userdata         (00708000, 06D6BFDF)    54.71 GB
 P36: flashinfo        (07473FDF, 00008000)    16 MB
 Backuping nvdata partition...
 Opening C:/Program Files (x86)/Medusa Pro Software/Backups/RC14MB_nvdata_0x20440_0x10000_22_05_2020_22_39_42.bin file...
 Elapsed time 00:00:01
 RPMB: Counter of the successful data write requests = 201.
LOG CHANGING BOOT CONFIG FROM MTK TO QUALCOMM :
Boot config succesfully changed! Disconnected.
LOG FORMATTING eMMC :
Factory Format will erase all eMMC data! Do you want to continue? Yes.
 Formating...Done.
 Disconnected.
LOG WRITING EXT CSD :
Writing EXT_CSD succesfully complete! Disconnected.
LOG CHANGING CID :
Changing CID to 90014A48414732650507DF06D0CE329B. Write CID succesfully completed.
 Disconnected.
LOG CHANGING CSD INFO :
Write CSD successfully completed. Disconnected.
LOG WRITING BOOT 1 & 2 :
Switched to boot area partition 1. Opening  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/BOOT1 Hynix eMMC  HAG2e_20_05_2020_21_56_58.bin file...
 Write data verification is enabled.
 Writing. Please wait... Done.
 Switched to boot area partition 2.
 Opening C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/BOOT2 Hynix eMMC HAG2e_20_05_2020_21_56_58.bin file...
LOG WRITING FULL DUMP VIA PARTITION MANAGER :
Partition table is found from file  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin. Don't forget to reconnect the device  after writing to see changes.
 Switched to user area.
 Writting partitions. Please wait...
 Writing partition GPT from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition modem from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition sbl1 from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition sbl1bak from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition aboot from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition abootbak from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition rpm from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition rpmbak from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition tz from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition tzbak from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition hyp from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition hypbak from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition pad from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition modemst1 from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition modemst2 from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition misc from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition fsc from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition ssd from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition splash from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition DDR from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition fsg from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition sec from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition boot from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition system from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition persist from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition cache from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition recovery from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition keystore from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition config from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition oem from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing partition userdata from  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/srf/Nouveau dossier/Hynix  eMMC HAG2e_21_05_2020_20_51_14.bin file...    Done.
 Writing is finished.
 Reconnect the device to see changes.
 Disconnected.
The Following 2 Users Say Thank You to starkrimes For This Useful Post:
Old 05-22-2020, 23:52   #2 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
LOG WRITING FRESH FLASH STOCK ROM :
Selected file:  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/rom/rawprogram_unsparse.xml.  Selected file:  C:/Users/STARKRIMES/Desktop/RIDGEFAB4G_V15/rom/patch0.xml.
 Backuping. Please wait...
 Reading partition modemst1...    Done.
 Reading partition modemst2...    Done.
 Backuping finished.
 #grenWriting. Please wait...
 Writing partition modem...    Done.
 Writing partition sbl1...    Done.
 Writing partition sbl1bak...    Done.
 Writing partition aboot...    Done.
 Writing partition abootbak...    Done.
 Writing partition rpm...    Done.
 Writing partition rpmbak...    Done.
 Writing partition tz...    Done.
 Writing partition tzbak...    Done.
 Writing partition hyp...    Done.
 Writing partition hypbak...    Done.
 Writing partition splash...    Done.
 Writing partition fsg...    Done.
 Writing partition sec...    Done.
 Writing partition boot...    Done.
 Writing partition system...    Done.
 Writing partition cache...    Done.
 Writing partition recovery...    Done.
 Writing partition userdata...    Done.
 Writing MBR...Done.
 Writing primary GPT...Done.
 Writing partition PrimaryGPT...    Done.
 Writing partition BackupGPT...    Done.
 Writing finished.
 Disconnected.
Old 05-22-2020, 23:56   #3 (permalink)
Member: 2508405
Sonork: 100.1671124
Thanks Meter: 48
nice job Bro you do Well
404 vs BMW
The Following User Says Thank You to PC-CLINIC For This Useful Post:
Old 05-22-2020, 23:58   #4 (permalink)
Member: 2508405
Sonork: 100.1671124
Thanks Meter: 48
404 vs BMW
Old 05-23-2020, 01:11   #5 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
404 vs BMW
THANKS MY BROTHER
it's just improving not a big deal
Old 05-23-2020, 07:46   #6 (permalink)
rebainoor's Avatar
Member: 231728
Thanks Meter: 1,463
Always on top brother
Good job
Have you resize userdata partition to max allowed ?
If you have final log post it please
The Following 2 Users Say Thank You to rebainoor For This Useful Post:
Old 05-23-2020, 20:35   #7 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
Good job
i did of course userdata resized on emmc tab cause it's sa,sung emmc bro
and thanks bro for your feedback
Old 05-23-2020, 20:46   #8 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
sorry here is the log by auto resizing
Partition table has been found on device. Writing MBR... Done
 Writing primary GPT... Done
 Writing secondary GPT... Done
 Operation finished
 Writing MBR... Done
 Operation finished
 Disconnected.
Old 05-24-2020, 13:41   #9 (permalink)
Member: 2105490
Thanks Meter: 20
good job But how could I change the cid because this Revision 1.8 memory always fails with it.
Old 05-24-2020, 14:33   #10 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
you need to know if emmc write protect is enabled or disabled to get success
The Following User Says Thank You to starkrimes For This Useful Post:
Old 05-24-2020, 16:45   #11 (permalink)
Member: 2105490
Thanks Meter: 20
How can I find out that because I failed to change the cid in all of my memories. You write that it was done but the cid stays the same
The Following User Says Thank You to billymore For This Useful Post:
Old 05-24-2020, 17:12   #12 (permalink)
starkrimes's Avatar
Member: 1191316
Thanks Meter: 556
for you doesn't change but for me yes cause also you need to know if the emmc is compatible with ur device
you can download phonerepair db to compare and check emmc compatibiliy before you think just bring emmc and put and cid will changed
Page generated in 0.51198 seconds with 7 queries
