Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 08-30-2019, 11:57   #1 (permalink)
Member: 143848
Thanks Meter: 101
A500fu dead after flashing [Answered]
Hi
I flashed a500fu with a combination firmware and phone is no power anymore.
I have connected it medusa box and trying to writhe in factory mode the combination firmware ( is this aright approach).
Below is unsuccessful log. Please help to revive it.
Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-A50FU
SRF : G:/MOBILES/SAMSUNG OCTO/JTAG/SAMSUNG_SM-A500FU_EMMC_R311MB.srf
Voltage : 2.0V
Bus Mode : 1 bit
Bus speed : Auto
Connecting...
Device : Samsung eMMC R311MB
Page size : 512 B
Block size : 512 B
Block count : 134217728
Size : 64.00 GB (65536.00 MB)
CID Info
CID : 150100523331314D42006360D4A8C15F
Manufacturer ID : 0X15
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X00
Product name : R311MB
Product revision : 0.0
Product serial number : (hex) 6360D4A8
Manufacturing date : 12/1998
CSD Info
CSD : D02701320F5903FFF6DBFFEF8E40400D
CSD structure :
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
EXTCSD Info
Revision 1.0 (for MMC v4.0)
Erase block size : 32768 Kbytes
Boot1 size : 25088 Kbytes
Boot2 size : 25088 Kbytes
RPMB size : 24576 Kbytes
Partition config : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK : No boot acknowledge sent (default)
Boot bus conditions : (0xC8) 11001000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + High Speed timings in boot operation
RST_n function : (0x00) RST_n signal is temporary disabled (default)
Max enhanced data size: 0 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Not found
Backup EXT_CSD saved to file C:/Program Files/Octoplus Pro JTAG Software/EXT_CSD Backups/R311MB_29_08_2019_17_36_09.bin.
Connect successful.
SW: 1.7.7; FW: 1.24.
Selected pit file: D:/z3x/A500FU/SM-A500FU VFG pit/A5ULTE_EUR_OPEN_HIDDEN180M.pit
Open file "D:/z3x/A500FU/COMBINATION_OXA_FA44_A500FUXXU1AOK1/COMBINATION_OXA_FA44_A500FUXXU1AOK1/COMBINATION_OXA_FA44_A500FUXXU1AOK1_OXA_CL3791014_ QB7278151_REV00_user_mid_noship_MULTI_CERT.tar.md5 ".
Writing MBR...
ERROR[012]: Write error.
At sector 0.
Disconnected.
Old 09-02-2019, 12:42   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,832
Hello.
As i can see from the Software log, your device wasn't detected correctly, please to repeat Connect operation again and check this values
Page generated in 0.25300 seconds with 7 queries
