01-10-2019, 20:11 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | LG D325 F8 "dead" boot repair question [Answered] is possible repair this phone D325F8 i already tried repair usb mode . but phone is deteted as QDLoader 9008 Code: CPU : Qualcomm MSM8610 Storage Device: Hynix eMMC H4G1d Device ID : 00900001 Block size : 512 bytes Blocks : 7634944 Storage size : 3728 Mb Connect successful. Disconnected Selected device model: LG D325F8 (MSM8610) USB Connecting. Please wait... Interface : USB CPU : Qualcomm MSM8610 Storage Device: Hynix eMMC H4G1d Device ID : 00909201 Block size : 512 bytes Blocks : 7634944 Storage size : 3728 Mb Opening "C:\Program Files\GsmServer\Medusa_old\Firmware\LG_D325F8_Repair.mf" file... Writing ABOOT section. Please wait... Done Writing BOOT section. Please wait... Done Disconnected Repair done. Code: Disconnected. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : D325 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_D325_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Hynix eMMC H4G1d Page size : 512 B Block size : 512 B Block count : 7634944 Size : 3728.00 MB --------------------------------------------------------------- CID Info CID : 90014A4834473164040509A2973B12D9 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H4G1d Product revision : 0.5 Product serial number : (hex) 9A2973B Manufacturing date : 01/2015 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFEF8A4040D3 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.6 (for MMC v4.5, v4.51) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x38) 00111000 Boot partition enable : User area (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 1908736 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/H4G1d_10_01_2019_16_03_29.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.2; FW: 1.24. Last edited by Medusa Box; 01-11-2019 at 07:14. |
01-11-2019, 07:13 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Please try to do "Factory Repair" procedure ("Factory repair" tab in Software) using the latest available original LG firmware for this device (in "*.tot", "*.dz" or "*.kdz" format). Post here full Software log. |
