05-10-2018, 14:15 | #1 (permalink) |
Junior Member Join Date: Aug 2008
Member: 841695 Status: Offline Thanks Meter: 0 | Any way to check how healthy is the EMMC using Medusa? [Answered] Is there any way to check how healthy is the EMMC using Medusa box? Or perhaps based on experience, the access speed, voltage or anything can be used as indicators? Sometimes on chip-off or direct the emmc, it reads good but still not working on the phone.. Thanks Last edited by Medusa Box; 05-10-2018 at 15:05. |
05-10-2018, 15:05 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hi. If this is Samsung eMMC, You can try to perform "SMART Report" and lock at count of bad blocks. For other brands no special solution; as partial solution, You can try to write big file and read it out, then compare in hex editor. If file, which was read out, will be the same as written file (without any changes), most likely, You can use this eMMC. Also You can use "Write data verification" option in the Software. This option also detects an errors with writing/reading data on eMMC. |
The Following 2 Users Say Thank You to Medusa Box For This Useful Post: |
