Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 06-09-2018, 14:07   #1 (permalink)
Niaz Hussain's Avatar
Member: 117640
Sonork: 100.1580505
Thanks Meter: 62
Thumbs up LG LS676 Dead Boot Repair Successully Done
LG LS676 Dead Boot Repair done
 Model Settings:
Interface : eMMC
Voltage   : 1.8V
Bus Mode  : 1 bit
Bus speed : Auto
Connecting...
Device       : Samsung eMMC Q316BB
Page size    : 512 B
Block size   : 512 B
Block count  : 30535680
Size         : 14.56 GB (14910.00 MB)
CID Info
CID                   : 15010051333136424202148DDC726453
Manufacturer ID       : 0X15
Device/BGA            : BGA (Discrete embedded)
OEM/Application ID    : 0X00
Product name          : Q316BB
Product revision      : 0.2
Product serial number : (hex) 148DDC72
Manufacturing date    : 06/2017
CSD Info
CSD                   : D02701320F5903FFF6DBFFEF8E40400D
CSD structure         : CSD version No. 1.2
SPEC version          : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
                        4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed            : 26 MHz
READ block length     : 512 Bytes
WP group enable       : YES
PERM_WRITE_PROTECT    : NO
TMP_WRITE_PROTECT     : NO
EXTCSD Info
Revision 1.8 (for MMC v5.1)
Erase block size      : 512 Kbytes
Boot1 size            : 4096 Kbytes
Boot2 size            : 4096 Kbytes
RPMB size             : 4096 Kbytes
Partition config      : (0x00) 00000000
Boot partition enable : Device not boot enabled (default)
(Bus width = 1Bit)
Boot ACK              : No boot acknowledge sent (default)
Boot bus conditions   : (0x00) 00000000
Boot bus width        : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions   : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode             : Use single data rate + backward compatible timings in boot operation (default)
RST_n function        : (0x01) RST_n signal is permanently enabled
Partitioning support  : Device supports partitioning features
Enhanced attribute    : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 7626752 Kbytes
Partitions attribute  : 0x0
Part setting completed: 0x0
GP partition 1 size   : 0 b
GP partition 2 size   : 0 b
GP partition 3 size   : 0 b
GP partition 4 size   : 0 b
Enhanced area size    : (0x0) 0 b
Enhanced area start   : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/Q316BB_07_06_2018_17_29_52.bin.
Connect successful.
SW: 1.5.8; FW: 1.23.
P00: GPT              (00000000, 00004000)	8 MB
P01: modem            (00004000, 00020000)	64 MB
P02: sbl1             (00024000, 00000400)	512 KB
P03: tz               (00024400, 00000800)	1024 KB
P04: rpm              (00024C00, 00000400)	512 KB
P05: aboot            (00025000, 00001000)	2048 KB
P06: sbl1bak          (00026000, 00000400)	512 KB
P07: tzbak            (00026400, 00000800)	1024 KB
P08: rpmbak           (00026C00, 00000400)	512 KB
P09: abootbak         (00027000, 00001000)	2048 KB
P10: modemst1         (00028000, 00000C00)	1536 KB
P11: modemst2         (00028C00, 00000C00)	1536 KB
P12: ssd              (00029800, 00000400)	512 KB
P13: DDR              (00029C00, 00000400)	512 KB
P14: spare3           (0002A000, 00000C00)	1536 KB
P15: fsc              (0002AC00, 00000400)	512 KB
P16: sec              (0002B000, 00000400)	512 KB
P17: keystore         (0002B400, 00000400)	512 KB
P18: encrypt          (0002B800, 00000400)	512 KB
P19: eksst            (0002BC00, 00000400)	512 KB
P20: devinfo          (0002C000, 00000800)	1024 KB
P21: config           (0002C800, 00000400)	512 KB
P22: spare1           (0002CC00, 00003400)	6.5 MB
P23: fota             (00030000, 00003000)	6 MB
P24: rct              (00033000, 00000400)	512 KB
P25: spare2           (00033400, 00000C00)	1536 KB
P26: raw_resources    (00034000, 00000800)	1024 KB
P27: raw_resourcesbak (00034800, 00000800)	1024 KB
P28: drm              (00035000, 00003000)	6 MB
P29: sns              (00038000, 00003000)	6 MB
P30: misc             (0003B000, 00005000)	10 MB
P31: fsg              (00040000, 00000C00)	1536 KB
P32: spare4           (00040C00, 00003400)	6.5 MB
P33: persist          (00044000, 00004000)	8 MB
P34: carrier          (00048000, 00014000)	40 MB
P35: laf              (0005C000, 0000C000)	24 MB
P36: boot             (00068000, 00008000)	16 MB
P37: recovery         (00070000, 00008000)	16 MB
P38: recoverybak      (00078000, 00008000)	16 MB
P39: factory          (00080000, 0000C000)	24 MB
P40: mpt              (0008C000, 00004000)	8 MB
P41: system           (00090000, 005DC000)	3000 MB
P42: lafbak           (0066C000, 0000C000)	24 MB
P43: cache            (00678000, 001C2000)	900 MB
P44: userdata         (0083A000, 014E4FDE)	10.45 GB
P45: grow             (01D1EFDE, 00000001)	512 b
Opening C:/Users/Niaz Khan/Downloads/LS676ZV9_02_2.tot file...
Signature OK.
Signature 2 OK.
Open file "C:/Users/Niaz Khan/Downloads/LS676ZV9_02_2.tot".
Write data verification is enabled.
Writing. Please wait...
Writing partition PrimaryGPT...	Done.
Writing partition modem...	Done.
Writing partition sbl1...	Done.
Writing partition tz...	Done.
Writing partition rpm...	Done.
Writing partition aboot...	Done.
Writing partition sbl1bak...	Done.
Writing partition tzbak...	Done.
Writing partition rpmbak...	Done.
Writing partition abootbak...	Done.
Writing partition sec...	Done.
Writing partition rct...	Done.
Writing partition raw_resources...	Done.
Writing partition raw_resourcesbak...	Done.
Writing partition misc...	Done.
Writing partition persist...	Done.
Writing partition laf...	Done.
Writing partition boot...	Done.
Writing partition recovery...	Done.
Writing partition recoverybak...	Done.
Writing partition factory...	Done.
Writing partition BackupGPT...	Done.
Writing is finished.
Disconnected.
The Following 2 Users Say Thank You to Niaz Hussain For This Useful Post:
Old 08-14-2018, 01:00   #2 (permalink)
Member: 2256239
share the "boot file" and the direct emmc pinout...... please, thanks
Old 08-15-2018, 08:33   #3 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,398
Hello.
SRF for this device model has been send us by Mr. Pijush Das, so You can download it from the folder "USER UPLOADED SRF (NOT TESTED)" via "Download *.srf" button in Software.
Page generated in 0.12384 seconds with 8 queries
