Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 08-15-2018, 15:54   #1 (permalink)
Member: 894739
Thumbs up Can not open program Medusa Pro [Solved]
i was trying repair boot of g532m samsung, so cant read data of phone, i check connections and try again, then program read emmc correctly, but after a 20 second appear a message "smart card not found", then update smartcard, update program medusa to 1.6.5 and try again, when i try to open program, i can't do it, and a message appear
Smart-Card: card blacklisted
#0: 00000000
iI need to repair the phone, because I turn it off by removing frp
sorry for my english, i speak spanish
Old 08-15-2018, 19:09   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 2,608
Hello.
Such error (with card) may appear, if there is no enough powering on USB port, where You have connected Box or there is a problem with eMMC connection - present shorts on PCB or soldered wires are too long. Please disconnect all devices from PC, reboot PC, connect Box directly to PC motherboard USB port (don't use any USB hubs, this is important for stable connection), re-update card and try to run Software again. When Software will start, check shorts on PCB, check soldering of all wires, make each wire as short as possible (max. 3-5 CM length) and try to connect the devcie again.
Old 08-15-2018, 21:52   #3 (permalink)
Member: 894739
Originally Posted by Medusa Box View Post
Hello.
was cable, sry and thanks for support
Page generated in 0.19482 seconds with 7 queries
