04-02-2019, 10:01 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | LG H810 not connect dead boot [Answered] Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Model Settings: Interface : USB Core : Qualcomm MSM8992 Loader : QLoader_v1 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Model Settings: Interface : USB Core : Qualcomm MSM8992 Loader : QLoader_v5_LG Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Model Settings: Interface : USB Core : Qualcomm MSM8992 Loader : QLoader_v2 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. Model Settings: Interface : USB Core : Qualcomm MSM8992 Loader : QLoader_v9 Connecting... Sending loader...OK. Loader not initialized. Loader is not suitable for this device. |
04-03-2019, 08:55 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. Please, check Software log attentive: Loader not initialized. Loader is not suitable for this device and try use forum search button. |
04-08-2019, 08:52 | #3 (permalink) |
Member: 310155 Status: Offline Thanks Meter: 1,313 | Model Settings: Interface : eMMC Brand : LG Model : H811 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H811_EMMC.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 2147483648 Size : 1024.00 GB (1048576.00 MB) --------------------------------------------------------------- CID Info CID : 11010030333247373400DC5A9471323D Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) DC5A9471 Manufacturing date : 03/1999 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.0 (for MMC v4.0) Erase block size : 512 Kbytes Boot1 size : 5504 Kbytes Boot2 size : 5504 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_08_04_2019_13_51_37.bin. Connect successful. --------------------------------------------------------------- SW: 1.7.3; FW: 1.24. Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H811_EMMC.srf". Write data verification is enabled. Writing GPT partition... Write verification error 1. Possible reasons: damaged or write protected eMMC. Disconnected. |
04-08-2019, 08:56 | #4 (permalink) | |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Quote:
