01-26-2020, 13:09 | #1 (permalink) |
Freak Poster Join Date: May 2011 Location: algeria
Member: 1582098 Status: Offline Thanks Meter: 17 | emmc pinout to medusa pro [Answered] DET PWR RESET CLK DATA GND on the other side the medusa pro box adapter has many pins EMMC D0,EMMC D1 ... 1.8v 2.8v how can i know which pin where it goes ? it's clear that the corresoonding GND and CLK and DATA0 goes to the same corresponding but how for others ? VCCQ or VCC for power ? DET ? RESET ? ... etc Last edited by Gsmserver; 01-31-2020 at 09:51. |
01-26-2020, 20:16 | #2 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | As I Know Router Don't Have EMMC Or EMCP Chip So It Won't Work With That Some Of Router Having JTAG Points But New Router Don't Have ...Mostly New Router Using SPI Connection Read Write...I AM Not Sure Medusa Pro Support SPI Connection Or Not..Better Post Motherboard Clear Image With All Chip ..So I Can Check Last edited by Gsmserver; 01-30-2020 at 16:07. |
The Following User Says Thank You to hitech care For This Useful Post: |
01-26-2020, 20:37 | #3 (permalink) |
Member: 1582098 Status: Offline Thanks Meter: 17 | ok thanks then this picture would be interessted the cpu and memory chip according to the datasheet if the chip is named : FMN4ET2TCK-25IG then it's Stacked Multi-Chip Product(MCP) Last edited by Gsmserver; 01-30-2020 at 16:08. |
01-30-2020, 11:23 | #4 (permalink) |
Member: 1834832 Status: Offline Thanks Meter: 1,450 | As Per Chip Name It Seems Non Brand EMMC/EMCP Try Chip Off Google Show BGA-162 Chip ..Try To Read Info Don't Touch Or Erase Any Data Just Post Log After That...I Try To Help U Last edited by Gsmserver; 01-30-2020 at 16:07. |
01-30-2020, 21:05 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: Under the Sky
Member: 678886 Status: Offline Sonork: 100.1661586 Thanks Meter: 171 | You dont need vcc and vccq if cant find them,You can plug usb cable board will get vcc vccq Last edited by Gsmserver; 01-31-2020 at 09:51. |
04-22-2021, 07:59 | #6 (permalink) | |
Freak Poster Join Date: Jun 2006 Location: Pendora Age: 45
Member: 299122 Status: Offline Sonork: 1658277 Thanks Meter: 54 | Quote:
cmastar | |
04-22-2021, 20:11 | #7 (permalink) | |
Product Supporter Join Date: Mar 2013 Location: JTAG/eMMC/UFS
Member: 1902789 Status: Offline Thanks Meter: 1,100 | Quote:
eMMC ISP Interface not for NAND Flash Memory, Bcoz eMMC have different I/O & Nand Flash Memory have different I/O. | |
