12-25-2017, 00:33 | #1 (permalink) |
Freak Poster Join Date: May 2010 Location: Toronto Age: 47
Member: 1295004 Status: Offline Sonork: 100.1610057 Thanks Meter: 29 | Empty eMMC question [Answered] Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 447166457 Size : 213.23 GB (218343.00 MB) --------------------------------------------------------------- CID Info CID : 5A5A00000000000000000000000101ED Manufacturer ID : 0X5A Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 1 Manufacturing date : 00/2014 --------------------------------------------------------------- CSD Info CSD : 3C3C0000000000000000000000FFFF31 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0.03 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : YES --------------------------------------------------------------- EXTCSD Info Erase block size : 51200 Kbytes Boot1 size : 16128 Kbytes Boot2 size : 16128 Kbytes RPMB size : 3584 Kbytes Partition config : (0xAE) 10101110 Boot partition enable : (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xFA) 11111010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : RST_n function : (0x02) RST_n signal is permanently disabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4027949056 Kbytes Partitions attribute : 0x7A Part setting completed: 0x9B GP partition 1 size : 780 MB GP partition 2 size : 1918 MB GP partition 3 size : 1498 MB GP partition 4 size : 3812 MB Enhanced area size : (0xC4800000) 3144 MB Enhanced area start : (0xF7C2CE00) 3964 MB ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/_24_12_2017_18_33_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. Whole proccess time: . Parsing device... Image size in bytes: 1315959296 Warning: Unknown file system type. Details: Sector offset: 0 Parse finished. Whole proccess time: 2 seconds : 0 ms. Parsing contacts........done. No contacts found. Parsing SMSs........done. No SMS info found. Welcome to Medusa Pro Software version 1.5.0. Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 447166457 Size : 213.23 GB (218343.00 MB) --------------------------------------------------------------- CID Info CID : 5A5A00000000000000000000000101ED Manufacturer ID : 0X5A Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 1 Manufacturing date : 00/2014 --------------------------------------------------------------- CSD Info CSD : 3C3C0000000000000000000000FFFF31 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0.03 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : YES --------------------------------------------------------------- EXTCSD Info Erase block size : 51200 Kbytes Boot1 size : 16128 Kbytes Boot2 size : 16128 Kbytes RPMB size : 3584 Kbytes Partition config : (0xAE) 10101110 Boot partition enable : (Bus width = 8Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xFA) 11111010 Boot bus width : x8 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : RST_n function : (0x02) RST_n signal is permanently disabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4027949056 Kbytes Partitions attribute : 0x7A Part setting completed: 0x9B GP partition 1 size : 780 MB GP partition 2 size : 1918 MB GP partition 3 size : 1498 MB GP partition 4 size : 3812 MB Enhanced area size : (0xC4800000) 3144 MB Enhanced area start : (0xF7C2CE00) 3964 MB ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/_24_12_2017_18_33_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.0; FW: 1.22. Last edited by Medusa Box; 12-25-2017 at 06:40. |
12-25-2017, 01:23 | #2 (permalink) |
Insane Poster Join Date: Dec 2016 Location: Belo Horizonte - MG
Member: 2658469 Status: Offline Thanks Meter: 20 | Seems your emmc was damage, see this; [QUOTE=modder1;12862286]I have emmc which show user area empty but it was not wiped at any time, can anyone advise on this type of thing please? Started. Reader #0: Generic EMV Smartcard Reader 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Unknown eMMC Page size : 512 B Block size : 512 B Block count : 447166457 Size : 213.23 GB (218343.00 MB) --------------------------------------------------------------- CID Info CID : 5A5A00000000000000000000000101ED Manufacturer ID : 0X5A Device/BGA : Device (removable) OEM/Application ID : 0X00 Product name : Product revision : 0.0 Product serial number : (hex) 1 Manufacturing date : 00/2014 --------------------------------------------------------------- CSD Info CSD : 3C3C0000000000000000000000FFFF31 CSD structure : CSD version No. 1.0 SPEC version : Allocated by MMCA Data read access time1: 0.03 ms TRAN speed : 0 MHz READ block length : 1 Bytes WP group enable : NO PERM_WRITE_PROTECT : YES TMP_WRITE_PROTECT : YES --------------------------------------------------------------- |
12-25-2017, 06:39 | #3 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Yes, mr. sidnei35 is right, as You can see from your Software log, there is a problem with eMMC chip or You have not connected eMMC correctly: Quote:
12-25-2017, 14:47 | #4 (permalink) |
Member: 1295004 Status: Offline Sonork: 100.1610057 Thanks Meter: 29 | Thank you guys was using the Moorc. Will try to wire directly to emmc. Really appreciate your help Sent from my iPhone using Tapatalk |
