07-24-2018, 14:10 | #1 (permalink) |
Freak Poster Join Date: Feb 2007
Member: 455296 Status: Offline Sonork: xxxxxxxxx Thanks Meter: 66 | [F1] SM-C7000 Dead Boot Repair [Answered] process has been successfull, but not turning on! first attempt : Code: Welcome to Medusa Pro Software version 1.5.9. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: Alcor Micro USB Smart Card Reader 1 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-J710FN SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-J710FN_EMMC.srf Voltage : 2.6V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC RX14MB Page size : 512 B Block size : 512 B Block count : 6293760 Size : 3073.13 MB --------------------------------------------------------------- CID Info CID : 150100525831344D4200E804D650734D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RX14MB Product revision : 0.0 Product serial number : (hex) E804D650 Manufacturing date : 07/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 0 Kbytes Boot1 size : 16512 Kbytes Boot2 size : 16512 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0xA0) 10100000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Max enhanced data size: 0 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0xE1C1C000) 3612 MB ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RX14MB_24_07_2018_13_28_56.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. Selected pit file: S:/MTN_Downloads/C7_Download/C7LTE_CHN_OPEN.pit Open file "S:/MTN_Downloads/C7_Download/BL_C7000ZCU2APL4_CL9089366_QB11794463_REV00_user_low_ship_MULTI_CERT/BL_C7000ZCU2APL4_CL9089366_QB11794463_REV00_user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... Done. Writing partition RPM... Done. Writing partition TZ... Done. Writing partition ABOOT... Done. Writing partition SEC... Done. Writing partition LKSECAPP... Done. Writing partition KEYMASTER... Done. Writing partition CMNLIB... Done. Writing partition DEVCFG... Done. Writing partition APDP... Done. Writing partition MSADP... Done. Writing partition APNHLOS... Done. Writing is finished. SW: 1.5.9; FW: 1.23. After Repair: Code: Connecting... Device : Samsung eMMC RX14MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100525831344D4200E804D650734D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RX14MB Product revision : 0.0 Product serial number : (hex) E804D650 Manufacturing date : 07/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 688128 Number of sectors : 7372800 Device Manufacturer :samsung Device Platform :msm8953 Build ID :MMB29M Display Build ID :MMB29M.C7000ZHU2APJ2 Release ID :6.0.1 Device Model :SM-C7000 Device Name :c7ltezh Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :c7ltezh-user 6.0.1 MMB29M C7000ZHU2APJ2 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RX14MB_24_07_2018_17_00_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000200) 256 KB P10: cmnlib (00005800, 00000200) 256 KB P11: cmnlib64 (00005A00, 00000200) 256 KB P12: fsg (00005C00, 00002000) 4 MB P13: pad (00007C00, 00000400) 512 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00000800) 1024 KB P31: keystore (00057000, 00000800) 1024 KB P32: config (00057800, 00000800) 1024 KB P33: dsp (00058000, 00008000) 16 MB P34: modem (00060000, 00030000) 96 MB P35: apnhlos (00090000, 00010000) 32 MB P36: persdata (000A0000, 00006000) 12 MB P37: reserved2 (000A6000, 00002000) 4 MB P38: system (000A8000, 00708000) 3600 MB P39: cache (007B0000, 00064000) 200 MB P40: userdata (00814000, FFDEA900) 2047 GB Disconnected. Last edited by Medusa Box; 07-24-2018 at 14:18. |
07-24-2018, 14:18 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. Try to do "Factory Repair" using another firmwares for this device model. Also try to write full firmware, not only "BL_*.md5" part. |
The Following User Says Thank You to Medusa Box For This Useful Post: |
07-24-2018, 17:36 | #3 (permalink) |
Member: 455296 Status: Offline Sonork: xxxxxxxxx Thanks Meter: 66 | Still the same: Code: Connecting... Device : Samsung eMMC RX14MB Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 150100525831344D4200E804D650734D Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : RX14MB Product revision : 0.0 Product serial number : (hex) E804D650 Manufacturing date : 07/2016 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15261696 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/RX14MB_24_07_2018_20_21_24.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.9; FW: 1.23. P00: GPT (00000000, 00002000) 4 MB P01: sbl1 (00002000, 00000400) 512 KB P02: sbl1bak (00002400, 00000400) 512 KB P03: ddr (00002800, 00000400) 512 KB P04: rpm (00002C00, 00000400) 512 KB P05: tz (00003000, 00001000) 2048 KB P06: aboot (00004000, 00001000) 2048 KB P07: sec (00005000, 00000200) 256 KB P08: lksecapp (00005200, 00000400) 512 KB P09: keymaster (00005600, 00000200) 256 KB P10: cmnlib (00005800, 00000200) 256 KB P11: cmnlib64 (00005A00, 00000200) 256 KB P12: fsg (00005C00, 00002000) 4 MB P13: pad (00007C00, 00000400) 512 KB P14: modemst1 (00008000, 00002000) 4 MB P15: modemst2 (0000A000, 00002000) 4 MB P16: efs (0000E000, 00008000) 16 MB P17: fsc (00016000, 00001A00) 3328 KB P18: ssd (00017A00, 00000200) 256 KB P19: devcfg (00017C00, 00000200) 256 KB P20: apdp (00017E00, 00000100) 128 KB P21: msadp (00017F00, 00000100) 128 KB P22: param (00018000, 00006000) 12 MB P23: backup (0001E000, 00002000) 4 MB P24: boot (00020000, 00010000) 32 MB P25: recovery (00030000, 00010000) 32 MB P26: bota (00040000, 00004000) 8 MB P27: fota (00044000, 00002000) 4 MB P28: persist (00046000, 00010000) 32 MB P29: persistent (00056000, 00000800) 1024 KB P30: steady (00056800, 00000800) 1024 KB P31: keystore (00057000, 00000800) 1024 KB P32: config (00057800, 00000800) 1024 KB P33: dsp (00058000, 00008000) 16 MB P34: modem (00060000, 00030000) 96 MB P35: apnhlos (00090000, 00010000) 32 MB P36: persdata (000A0000, 00006000) 12 MB P37: reserved2 (000A6000, 00002000) 4 MB P38: system (000A8000, 00708000) 3600 MB P39: cache (007B0000, 00064000) 200 MB P40: userdata (00814000, 06C67FD8) 54.2 GB Selected pit file: M:/tmp/C7000/C7LTE_CHN_OPEN.pit Open file "M:/tmp/C7000/AP_C7000ZHU2BQL2_CL12482124_QB15993590_REV00_user_low_ship_MULTI_CERT_meta.tar.md5". Open file "M:/tmp/C7000/BL_C7000ZHU2BQL2_CL12482124_QB15993590_REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "M:/tmp/C7000/CP_C7000ZHU2BQL2_CP8267391_CL12482124_QB15993590_REV00_user_low_ship_MULTI_CERT.tar.md5". Open file "M:/tmp/C7000/CSC_ZZH_C7000ZZH2BQL2_CL12482124_QB15993590_REV00_user_low_ship_MULTI_CERT.tar.md5". Writing MBR...Done. Writing primary GPT...Done. Writing secondary GPT...Done. Writing PIT Write data verification is enabled. Writing. Please wait... Writing partition SBL1... Done. Writing partition RPM... Done. Writing partition TZ... Done. Writing partition ABOOT... Done. Writing partition SEC... Done. Writing partition LKSECAPP... Done. Writing partition KEYMASTER... Done. Writing partition CMNLIB... Done. Writing partition DEVCFG... Done. Writing partition APDP... Done. Writing partition MSADP... Done. Writing partition BOOT... Done. Writing partition RECOVERY... Done. Writing partition PERSIST... Done. Writing partition DSP... Done. Writing partition MODEM... Done. Writing partition APNHLOS... Done. Writing partition SYSTEM... Done. Writing partition CACHE... Done. Writing is finished. SW: 1.5.9; FW: 1.23. Disconnected. |
11-03-2018, 10:14 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please look here: http://forum.gsmhosting.com/vbb/f664...wered-2497585/. |
