02-26-2020, 15:23 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | G390F Smart repair problem (second phone) [Answered] Code: Model Settings: Interface : eMMC Brand : Samsung Model : SM-G390F SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G390F_EMMC.srf Voltage : 2.4V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC QE63MB Page size : 512 B Block size : 512 B Block count : 30777344 Size : 14.68 GB (15028.00 MB) --------------------------------------------------------------- CID Info CID : 150100514536334D4200A6FAD3AA6563 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : QE63MB Product revision : 0.0 Product serial number : (hex) A6FAD3AA Manufacturing date : 06/2018 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8E40400D CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.8 (for MMC v5.1) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 16384 Kbytes Partition config : (0x48) 01001000 Boot partition enable : Boot partition 1 (Bus width = 4Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0x01) 00000001 Boot bus width : x4 (sdr/ddr) bus width in boot operation mode Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7692288 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : ab400000 bytes Device sector size : 512 bytes Partition offset : 491520 Number of sectors : 5570560 Device Manufacturer : samsung Device Platform : exynos5 Build ID : M1AJQ Display Build ID : M1AJQ.G390FXXU4BSB3 Release ID : 8.1.0 Device Model : SM-G390F Device Name : xcover4ltexx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : xcover4ltexx-user 8.1.0 M1AJQ G390FXXU4BSB3 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/QE63MB_26_02_2020_15_54_10.bin. Connect successful. --------------------------------------------------------------- SW: 2.0.5; FW: 1.24. P00: GPT (00000000, 00002000) 4 MB P01: BOTA0 (00002000, 00002000) 4 MB P02: BOTA1 (00004000, 00002000) 4 MB P03: EFS (00006000, 0000A000) 20 MB P04: CPEFS (00010000, 00004000) 8 MB P05: m9kefs1 (00014000, 00002000) 4 MB P06: m9kefs2 (00016000, 00002000) 4 MB P07: m9kefs3 (00018000, 00002000) 4 MB P08: CARRIER (0001A000, 00000800) 1024 KB P09: PARAM (0001A800, 00004000) 8 MB P10: BOOT (0001E800, 00010000) 32 MB P11: RECOVERY (0002E800, 00013000) 38 MB P12: OTA (00041800, 00004000) 8 MB P13: CDMA-RADIO (00045800, 00002000) 4 MB P14: RADIO (00047800, 0002C000) 88 MB P15: TOMBSTONES (00073800, 00000800) 1024 KB P16: DNT (00074000, 00000800) 1024 KB P17: PERSISTENT (00074800, 00000400) 512 KB P18: STEADY (00074C00, 00002000) 4 MB P19: RESERVED2 (00076C00, 00001400) 2560 KB P20: SYSTEM (00078000, 00550000) 2720 MB P21: CACHE (005C8000, 00064000) 200 MB P22: HIDDEN (0062C000, 0001E000) 60 MB P23: CP_DEBUG (0064A000, 00002800) 5 MB P24: NAD_FW (0064C800, 0000A000) 20 MB P25: NAD_REFER (00656800, 00000800) 1024 KB P26: USERDATA (00657000, 01700000) 11.5 GB Backuping EFS partition... Opening C:/Program Files/Medusa Pro Software/Backups/QE63MB_EFS_0x6000_0xa000_26_02_2020_15_54_10.bin file... Reading. Please wait... Done. Elapsed time 00:00:08 SW: 2.0.5; FW: 1.24. READ full emmc done, then smart repair performed: Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G390F_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to boot area partition 2. Writing BOOT2 partition... Done. Switched to user area. Writing GPT partition... Done. Writing BOTA0 partition... Done. Writing BOTA1 partition... Done. Writing CPEFS partition... Done. Writing m9kefs1 partition... Done. Writing m9kefs2 partition... Done. Writing m9kefs3 partition... Done. Writing CARRIER partition... Done. Writing PARAM partition... Done. Writing BOOT partition... Done. Writing RECOVERY partition... Done. Writing OTA partition... Done. Writing CDMA-RADIO partition... Done. Writing RADIO partition... Done. Writing TOMBSTONES partition... Done. Writing DNT partition... Done. Writing PERSISTENT partition... Done. Writing STEADY partition... Done. Writing RESERVED2 partition... Done. Writing HIDDEN partition... Done. Writing CP_DEBUG partition... Done. Writing NAD_FW partition... Done. Writing NAD_REFER partition... Done. Smart Repair is successfully complete. SW: 2.0.5; FW: 1.24. Disconnected. Now I have 2 dead phones. I need solution to repair them. |
The Following User Says Thank You to Raklm For This Useful Post: |
02-27-2020, 10:20 | #7 (permalink) |
Member: 5926 Status: Offline Thanks Meter: 275 | here is full dump, readed in initial working state. https://mega.nz/#!y8YUiSaS!TErvpDDrO...Z_C-0txlsm_57I |
The Following 2 Users Say Thank You to Raklm For This Useful Post: |
03-02-2020, 08:42 | #11 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | We've re-upload SRF file fro this device, if You have any issues before, then re-download SRF file, re-open it in Software and try to do Smart Repair operation again |
The Following 4 Users Say Thank You to Medusa Box For This Useful Post: |
07-03-2020, 22:27 | #12 (permalink) | |
Junior Member Join Date: Nov 2014
Member: 2297324 Status: Offline Thanks Meter: 6 | Samsung g390f Quote:
