Member: 2948043
Thanks Meter: 3 | Quote:
Originally Posted by starkrimes look to the back of phone under battery if it's written assembled in algeria
second thing post all software log not few |
I did not find this sentence .. ( assembled in algeria..
this is only : designed and engineered by samsung
manufactured in china.
so i do this.. 1/ Smart repair by medusa pro (stay dead)... logo: Quote: Please disconnect battery and USB cable. Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G532F
SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf
Voltage : 1.8V
Bus Mode : 1 bit
Bus speed : Auto Connecting...
Device : Hynix eMMC H8G4u
Page size : 512 B
Block size : 512 B
Block count : 15269888
Size : 7.28 GB (7456.00 MB)
--------------------------------------------------------------- CID Info
CID : 90014A4838473475920137DB0AEB45A3
Manufacturer ID : 0X90
Device/BGA : BGA (Discrete embedded)
OEM/Application ID : 0X4A
Product name : H8G4u
Product revision : 0.1
Product serial number : (hex) 37DB0AEB
Manufacturing date : 04/2018
--------------------------------------------------------------- CSD Info
CSD : D02701320F5903FFFFFFFFE78A40002B
CSD structure : CSD version No. 1.2
SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5,
4.51, 5.0, 5.01, 5.1
Data read access time1: 15 ms
TRAN speed : 26 MHz
READ block length : 512 Bytes
WP group enable : YES
PERM_WRITE_PROTECT : NO
TMP_WRITE_PROTECT : NO
--------------------------------------------------------------- EXTCSD Info
Revision 1.7 (for MMC v5.0, v5.01)
Erase block size : 512 Kbytes
Boot1 size : 4096 Kbytes
Boot2 size : 4096 Kbytes
RPMB size : 4096 Kbytes
Partition config : (0x48) 01001000
Boot partition enable : Boot partition 1 (Bus width = 1Bit)
Boot ACK : Boot acknowledge sent during boot operation Bit
Boot bus conditions : (0x00) 00000000
Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default)
Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default)
Boot mode : Use single data rate + backward compatible timings in boot operation (default)
RST_n function : (0x01) RST_n signal is permanently enabled
Partitioning support : Device supports partitioning features
Enhanced attribute : Device can have enhanced technological features in partitions and user data area.
Max enhanced data size: 3817472 Kbytes
Partitions attribute : 0x0
Part setting completed: 0x0
GP partition 1 size : 0 b
GP partition 2 size : 0 b
GP partition 3 size : 0 b
GP partition 4 size : 0 b
Enhanced area size : (0x0) 0 b
Enhanced area start : (0x0) 0 b
---------------------------------------------------------------Searching Android build info...
Ok
Disk/Image size : d2000000 bytes
Device sector size : 512 bytes
Partition offset : 393216
Number of sectors : 6307840
Device Manufacturer : samsung
Device Platform : mt6737t
Build ID : MMB29T
Display Build ID : MMB29T.G532FXWU1ARE1
Release ID : 6.0.1
Device Model : SM-G532F
Device Name : grandpplteser
Architecture ABI : armeabi-v7a
Architecture ABI2 : armeabi
Architecture ABI List : armeabi-v7a,armeabi
Build Description : grandpplteser-user 6.0.1 MMB29T G532FXWU1ARE1 release-keys
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_25_05_2020_09_03_33.bin. Connect successful.
--------------------------------------------------------------- SW: 2.0.9; FW: 1.24.
P00: GPT (00000000, 00002000) 4 MB
P01: BOTA0 (00002000, 00002000) 4 MB
P02: nvram (00004000, 00004000) 8 MB
P03: lk (00008000, 00001000) 2048 KB
P04: BOTA1 (00009000, 00001000) 2048 KB
P05: secro (0000A000, 00003800) 7 MB
P06: seccfg (0000D800, 00000400) 512 KB
P07: efuse (0000DC00, 00000400) 512 KB
P08: tee1 (0000E000, 00003000) 6 MB
P09: BOTA2 (00011000, 00003000) 6 MB
P10: EFS (00014000, 00004000) 8 MB
P11: nvdata (00018000, 00010000) 32 MB
P12: PARAM (00028000, 00004000) 8 MB
P13: recovery (0002C000, 00008000) 16 MB
P14: boot (00034000, 00008000) 16 MB
P15: md1img (0003C000, 00010000) 32 MB
P16: md1dsp (0004C000, 00002000) 4 MB
P17: keystore (0004E000, 00004000) 8 MB
P18: omekeystore (00052000, 00001C00) 3584 KB
P19: proinfo (00053C00, 00001400) 2560 KB
P20: para (00055000, 00000400) 512 KB
P21: PERSISTENT (00055400, 00000400) 512 KB
P22: STEADY (00055800, 00000800) 1024 KB
P23: protect1 (00056000, 00004000) 8 MB
P24: protect2 (0005A000, 00004000) 8 MB
P25: RESERVE2 (0005E000, 00002000) 4 MB
P26: system (00060000, 00604000) 3080 MB
P27: cache (00664000, 000C8000) 400 MB
P28: hidden (0072C000, 0001E000) 60 MB
P29: userdata (0074A000, 00744000) 3720 MB
Backuping EFS partition...
Opening C:/Program Files/Medusa Pro Software/Backups/H8G4u_EFS_0x14000_0x4000_25_05_2020_09_03_33.bin file...
Reading. Please wait... Done.
Elapsed time 00:00:03 SW: 2.0.9; FW: 1.24.
Backuping nvdata partition...
Opening C:/Program Files/Medusa Pro Software/Backups/H8G4u_nvdata_0x18000_0x10000_25_05_2020_09_03_33.b in file...
Elapsed time 00:00:12 SW: 2.0.9; FW: 1.24.
Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532F_EMMC_QN16BB.srf". Write data verification is enabled.
Switched to boot area partition 1.
Writing BOOT1 partition... Done.
Switched to user area.
Writing GPT partition... Done.
Writing BOTA0 partition... Done.
Writing lk partition... Done.
Writing BOTA1 partition... Done.
Writing secro partition... Done.
Writing seccfg partition... Done.
Writing efuse partition... Done.
Writing tee1 partition... Done.
Writing BOTA2 partition... Done.
Writing EFS partition... Done.
Writing PARAM partition... Done.
Writing recovery partition... Done.
Writing boot partition... Done.
Writing md1img partition... Done.
Writing md1dsp partition... Done.
Writing keystore partition... Done.
Writing omekeystore partition... Done.
Writing proinfo partition... Done.
Writing para partition... Done.
Writing PERSISTENT partition... Done.
Writing STEADY partition... Done. Smart Repair is successfully complete. SW: 2.0.9; FW: 1.24. Disconnected. | 2/ repair samsung devices using factory files, by these files (2) (stay dead) : Quote:
GRANDPPLTE_CIS_SER.pit
BL_G532FXWU1ARG4_CL13981262_QB18927805_REV00_user_ low_ship_MULTI_CERT.tar.md5 | logo: Quote: Please disconnect battery and USB cable. Model Settings:
Interface : eMMC
Brand : Samsung
Model : SM-G532F
Voltage : 1.8V
Bus Mode : 1 bit
Page size : 512 B
Block size : 512 B
TRAN speed : 26 MHz
Ok
Build ID : MMB29T
Release ID : 6.0.1
Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_25_05_2020_09_10_10.bin. Connect successful.
Opening C:/Program Files/Medusa Pro Software/Backups/H8G4u_EFS_0x14000_0x4000_25_05_2020_09_10_10.bin file...
Opening C:/Program Files/Medusa Pro Software/Backups/H8G4u_nvdata_0x18000_0x10000_25_05_2020_09_10_10.b in file...
Selected pit file: C:/Users/...../Desktop/GRANDPPLTE_CIS_SER.pit
Open file "C:/Users/...../Desktop/BL_G532FXWU1ARG4_CL13981262_QB18927805_REV00_user_ low_ship_MULTI_CERT.tar.md5".
Writing MBR...Done.
Writing primary GPT...Done.
Writing secondary GPT...Done.
Writing PIT Write data verification is enabled.
Writing. Please wait...
Writing partition BOOTLOADER... from 0 to 14D Done.
Writing partition lk... from 8000 to 481 Done.
Writing partition efuse... from DC00 to 2 Done.
Writing partition tee1... from E000 to 27A Done.
Writing partition PARAM... from 28000 to 5B4 Done.
Writing is finished. SW: 2.0.9; FW: 1.24. | so, what i can to do after that ... ? . |
