09-16-2017, 14:45 | #1 (permalink) |
No Life Poster Join Date: Aug 2010 Location: SearchinG ... Age: 39
Member: 1369772 Status: Offline Thanks Meter: 297 | G532G After Boot repair Hang on logo !! Please Help After flash phone automatically goes to Recovery Mode.... and show below error E:failed to mount/efs (Invalid argument) Repair Log Welcome to Medusa Pro Software version 1.4.4. Started. Reader #0: Generic EMV Smartcard Reader 0 Downloaded and installed file C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532G_EMMC.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : SM-G532G SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532G_EMMC.srf Voltage : 1.8V Bus Mode : 1 Bus speed : Auto Connecting... Device : Hynix eMMC H8G4u Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 90014A483847347592011E2538106485 Manufacturer ID : 0X90 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X4A Product name : H8G4u Product revision : 0.1 Product serial number : (hex) 1E253810 Manufacturing date : 06/2017 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFFFFFFFE78A40002B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 512 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : 01001000 Boot partition enable : Boot partition 1 (Bus width = 1Bit) Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3817472 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Ok Disk/Image size : d2000000 bytes Device sector size : 512 bytes Partition offset : 393216 Number of sectors : 6307840 Device Manufacturer : samsung Device Platform : mt6737t Build ID : MMB29T Display Build ID : MMB29T.G532GDXU1APJ7 Release ID : 6.0.1 Device Model : SM-G532G Device Name : grandppltedx Architecture ABI : armeabi-v7a Architecture ABI2 : armeabi Architecture ABI List : armeabi-v7a,armeabi Build Description : grandppltedx-user 6.0.1 MMB29T G532GDXU1APJ7 release-keys Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/H8G4u_16_09_2017_14_24_07.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.4; FW: 1.22. P00: GPT (00000000, 00002000) P01: BOTA0 (00002000, 00002000) P02: nvram (00004000, 00004000) P03: lk (00008000, 00001000) P04: BOTA1 (00009000, 00001000) P05: secro (0000A000, 00003800) P06: seccfg (0000D800, 00000400) P07: efuse (0000DC00, 00000400) P08: tee1 (0000E000, 00003000) P09: BOTA2 (00011000, 00003000) P10: EFS (00014000, 00004000) P11: nvdata (00018000, 00010000) P12: PARAM (00028000, 00004000) P13: recovery (0002C000, 00008000) P14: boot (00034000, 00008000) P15: md1img (0003C000, 00010000) P16: md1dsp (0004C000, 00002000) P17: keystore (0004E000, 00004000) P18: omekeystore (00052000, 00001C00) P19: proinfo (00053C00, 00001400) P20: para (00055000, 00000400) P21: PERSISTENT (00055400, 00000400) P22: STEADY (00055800, 00000800) P23: protect1 (00056000, 00004000) P24: protect2 (0005A000, 00004000) P25: RESERVE2 (0005E000, 00002000) P26: system (00060000, 00604000) P27: cache (00664000, 000C8000) P28: hidden (0072C000, 0001E000) P29: userdata (0074A000, 00744000) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_SM-G532G_EMMC.srf". Write data verification is enabled. Switched to boot area partition 1. Writing BOOT1 partition... Done. Switched to user area. Writing GPT partition... Done. Writing bota0 partition... Done. Writing lk partition... Done. Writing bota1 partition... Done. Writing secro partition... Done. Writing seccfg partition... Done. Writing efuse partition... Done. Writing tee1 partition... Done. Writing bota2 partition... Done. Writing efs partition... Done. Writing param partition... Done. Writing recovery partition... Done. Writing boot partition... Done. Writing md1img partition... Done. Writing md1dsp partition... Done. Writing keystore partition... Done. Writing omekeystore partition... Done. Writing proinfo partition... Done. Writing para partition... Done. Writing persistent partition... Done. Writing steady partition... Done. Smart Repair is successfully complete. SW: 1.4.4; FW: 1.22. Disconnected. |
09-18-2017, 07:26 | #3 (permalink) | |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Quote:
The Following User Says Thank You to Medusa Box For This Useful Post: |
