09-20-2017, 13:54 | #1 (permalink) |
Freak Poster Join Date: Mar 2016 Location: HUAWEI
Member: 2548753 Status: Offline Thanks Meter: 256 | GT-I9070 repair boot done Started. Reader #0: Generic EMV Smartcard Reader 0 Downloaded and installed file C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9070_EMMC.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : Samsung Model : GT-I9070 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9070_EMMC.srf Voltage : 2.0V Bus Mode : 1 Bus speed : Auto Connecting... Device : Sandisk eMMC SEM08G Page size : 512 B Block size : 512 B Block count : 15269888 Size : 7.28 GB --------------------------------------------------------------- CID Info CID : 45010053454D303847900813682C700F Manufacturer ID : 0X45 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : SEM08G Product revision : 9.0 Product serial number : (hex) 813682C Manufacturing date : 07/2013 --------------------------------------------------------------- CSD Info CSD : D00F00320F5903FFFFFFFFFF92424011 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 10 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 4096 Kbytes Boot1 size : 2048 Kbytes Boot2 size : 2048 Kbytes RPMB size : 128 Kbytes Partition config : 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 3768320 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info...Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/SEM08G_20_09_2017_14_18_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.4.4; FW: 1.22. P00: GPT (00000000, 00000400) P01: PIT (00000400, 00000800) P02: CSPSA FS (00000C00, 00000C00) P03: EFS (00002000, 00005000) P04: Modem FS (00007000, 00008000) P05: SBL (0000F800, 00001000) P06: SBL_2 (00010800, 00001000) P07: PARAM (00011800, 00008000) P08: IPL Modem (00019800, 00001000) P09: Modem (0001A800, 00008000) P10: Kernel (00022800, 00008000) P11: Kernel2 (0002A800, 00008000) P12: SYSTEM (00032800, 00132000) P13: DATAFS (00164800, 00400000) P14: CACHEFS (00564800, 00099000) P15: HIDDEN (005FD800, 000A0000) P16: Fota (0069D800, 00019000) P17: UMS (006B6800, 007D5000) Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-I9070_EMMC.srf". Write data verification is enabled. Writing GPT partition... Done. Writing PIT partition... Done. Writing CSPSA FS partition... Done. Writing SBL partition... Done. Writing SBL_2 partition... Done. Writing PARAM partition... Done. Writing IPL Modem partition... Done. Writing RDHSP partition... Done. Smart Repair is successfully complete. SW: 1.4.4; FW: 1.22. Disconnected. Last edited by Medusa Box; 09-20-2017 at 14:56. |
The Following User Says Thank You to Medofficiel For This Useful Post: |
