Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Medusa
Old 02-16-2018, 16:54   #1 (permalink)
Member: 934255
Thanks Meter: 63
GT-I9195 repair question [Answered]
For repair i9195 is obligatory to use rj45? or can i use the jig adaptor? if is i dont find ground in the same side of the adaptor.. can i conect on the oposite side?
Old 02-16-2018, 17:05   #2 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,394
You shouldn't use RJ45, there is RJ50 on JTAG picture (JATG connector in old Medusa Box - RJ50).
Yes.
Old 02-16-2018, 17:47   #3 (permalink)
Member: 934255
Thanks Meter: 63
The problem is that i dont have the tool to do the rj50
What i think was i cut a rj45 cable and i have 8 wires ( on the picture we need to conect nine but "reset" is not obligatory) can i conect the other 8 with the correct order?
Old 02-17-2018, 10:56   #4 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,394
No, You can't usr RJ45 connector.
If You have Medusa Pro Box, You can repair this device via JTAG also, no need RJ50 connector, just use 20-pin adapter. To look at Medusa Pro Box JTAG pinout picture (20 pin), run Octoplus JTAG Pro Software, select "JTAG" option and press "Box Pinout (JTAG)" button:
To look at Octoplus Box JTAG cable's pinout picture (10 pin), run Octoplus JTAG Software and go to "Support & Options" tab:
Medusa Pro 20-pin adapter:
GND contacts are from the opposite side of adapter.
Also note, that repairing of this device is supported via eMMC (ISP). You can download SFR for repairing of this device via eMMC from the Support Area.
Old 02-19-2018, 20:19   #5 (permalink)
Member: 934255
Thanks Meter: 63
Already clean but i dont see anything to solider
i dont see here to solder the clk point:
https://ibb.co/kou3RS
Old 02-20-2018, 06:13   #6 (permalink)
Medusa Box's Avatar
Member: 1538383
Sonork: 100.1587278
Thanks Meter: 3,394
Press "Pinout" button to look and eMMC pinout picture and then use mouse wheel to increase picture size to look at pinout in details. You must clean the lacquer coating on PCB to solder the CLK wire.
Page generated in 0.12901 seconds with 8 queries
