01-16-2018, 16:32 | #1 (permalink) |
Freak Poster Join Date: Oct 2012
Member: 1825048 Status: Offline Thanks Meter: 10 | GT-N7100 repair problem [Answered] Model Settings: Interface : eMMC Brand : Samsung Model : GT-N7100 SRF : C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC VTU00M Page size : 512 B Block size : 512 B Block count : 4294967295 Size : 2048.00 GB (2097152.00 MB) --------------------------------------------------------------- CID Info CID : 15010056545530304DF74930030ECFC1 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : VTU00M Product revision : 15.7 Product serial number : (hex) 4930030E Manufacturing date : 12/2012 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFFF8E40406D CSD structure : SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Erase block size : 130560 Kbytes Boot1 size : 32640 Kbytes Boot2 size : 32640 Kbytes RPMB size : 32640 Kbytes Partition config : (0xFF) 11111111 Boot partition enable : User area Boot ACK : Boot acknowledge sent during boot operation Bit Boot bus conditions : (0xFF) 11111111 Boot bus width : Reset boot bus conditions : Retain BOOT_BUS_WIDTH and BOOT_MODE values after boot operation Boot mode : RST_n function : (0x03) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 4261674496 Kbytes Partitions attribute : 0xFF Part setting completed: 0xFF GP partition 1 size : 255.5 MB GP partition 2 size : 255.5 MB GP partition 3 size : 255.5 MB GP partition 4 size : 255.5 MB Enhanced area size : (0xFF80000) 255.5 MB Enhanced area start : (0xFFFFFE00) 4096 MB Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/VTU00M_16_01_2018_19_00_10.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.1; FW: 1.22. Repairing from file "C:/Program Files/Medusa Pro Software/firmwareFolder/SAMSUNG_GT-N7100_EMMC_VTU00M.srf". Write data verification is disabled. Switch error!!! Writing BOOT1 partition... ERROR[012]: Write error. At sector 0 Attempting to write... Disconnected. Last edited by Medusa Box; 01-16-2018 at 19:23. |
01-16-2018, 19:22 | #2 (permalink) | ||
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,397 | Hello. As You can see from your Software log, You have not connected the device correctly or eMMC has HW problems - eMMC size (capacity) can't be 2048.00 GB: Quote:
When the device will be corrected correctly, You can try to perform the repair operation. | ||
