04-24-2018, 18:18 | #1 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Lagos Nigeria
Member: 1840260 Status: Offline Thanks Meter: 166 | GT-P7300 "dead" boot repair question [Updated] with factory repair because write partition not highlight help anyone Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG4FA Page size : 512 B Block size : 512 B Block count : 30801920 Size : 14.69 GB (15040.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414734464112E5179DA3AED7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG4FA Product revision : 1.2 Product serial number : (hex) E5179DA3 Manufacturing date : 10/2011 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8A404067 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7348224 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MAG4FA_24_04_2018_09_48_39.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.7; FW: 1.23. Last edited by Octopus box; 04-25-2018 at 15:22. |
04-25-2018, 04:50 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Hello. If partitions are not highlighting after parsing, this means, that necessary partitions are not present in selected firmware file. Try to use another PIT file, try to select another firmwares. Also please upload somewhere these PIT file and firmware and post here links, we will check them and write You the result. |
04-25-2018, 09:23 | #4 (permalink) |
Member: 1840260 Status: Offline Thanks Meter: 166 | https://androidfilehost.com/?fid=817550096634755728 pit link https://androidfilehost.com/?fid=889764386195929122 firmware Last edited by west007; 04-25-2018 at 09:30. |
04-25-2018, 14:39 | #5 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | PIT file, which You have uploaded (tried to use) is incorrect or has an old unsupported format. Try to find another PIT file. Also You can read full flash from the same working device and write it into your "dead" device. |
04-25-2018, 15:20 | #6 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Please check your PM, we have sent You "Boot Area Partition 1", "Boot Area Partition 2" and "Userdata" backups. Try to write them and check, whether device goes into Download (Emergency) Mode. |
04-25-2018, 15:46 | #8 (permalink) |
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | Just connect the device, check (select) "Boot Area Partition 1" in Software, press "Write" button, select "Boot Area Partition 1" binary file and write it. The same for "Boot Area Partition 2" and "userdata". |
05-09-2018, 12:00 | #9 (permalink) | |
Member: 1840260 Status: Offline Thanks Meter: 166 | Quote:
when i try to write boot i get this error | |
05-09-2018, 15:07 | #11 (permalink) |
Member: 1840260 Status: Offline Thanks Meter: 166 | Welcome to Medusa Pro Software version 1.5.7. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Please disconnect battery and USB cable. Model Settings: Interface : eMMC Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Samsung eMMC MAG4FA Page size : 512 B Block size : 512 B Block count : 30801920 Size : 14.69 GB (15040.00 MB) --------------------------------------------------------------- CID Info CID : 1501004D414734464112E5179DA3AED7 Manufacturer ID : 0X15 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : MAG4FA Product revision : 1.2 Product serial number : (hex) E5179DA3 Manufacturing date : 10/2011 --------------------------------------------------------------- CSD Info CSD : D02701320F5903FFF6DBFFEF8A404067 CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.5 (for MMC v4.41) Erase block size : 512 Kbytes Boot1 size : 0 Kbytes Boot2 size : 0 Kbytes RPMB size : 0 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x00) RST_n signal is temporary disabled (default) Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 7348224 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Not found --------------------------------------------------------------- Backup EXT_CSD saved to file C:/Program Files/Medusa Pro Software/EXT_CSD Backups/MAG4FA_09_05_2018_06_36_05.bin. Connect successful. --------------------------------------------------------------- SW: 1.5.7; FW: 1.23. Please select length. Please select length. connection sucessfull when i tried to write boot partition i get length larger than target block size |
05-09-2018, 15:33 | #12 (permalink) | |||
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,398 | As You can see from your Software log, connection is not successful or your eMMC is damaged - sizes of the following eMMC partitions' areas can't be zeros: Quote:
At first try to set Boot1 and Boot2 sizes" to 512 KB, and RPMB size to 128 KB (go to "eMMC service" tab in Software, "eMMC geometry edit" button). Then re-connect eMMC and check whether these sizes were correctly changed. Post here full Software log with "eMMC geometry edit" operation. If sizes' settings were correctly changed, try to write "Boot Area Partition 1", "Boot Area Partition 2" and "Userdata" backups. Also post here full Software log. | |||
The Following User Says Thank You to Medusa Box For This Useful Post: |
