06-05-2018, 09:14 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Georgia
Member: 772384 Status: Offline Thanks Meter: 40 | H790 boot repair question [Answered] Welcome to Medusa Pro Software version 1.6.0. Started. Reader #0: Alcor Micro USB Smart Card Reader 0 Reader #1: FT SCR2000 0 Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(EXT_CSD_LG H790) TOSHIBA EMMC 016G72.BIN. Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(LG H790) TOSHIBA EMMC 016G72_FULL.RAR. Downloaded file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/(LIVE_LOG LG H790) TOSHIBA EMMC 016G72.TXT. Downloaded and installed file C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H790 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H790 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... ERROR[001]: Can not connect. No target device present. Please disconnect battery and USB cable. Model Settings: Interface : eMMC Brand : LG Model : H790 SRF : C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf Voltage : 1.8V Bus Mode : 1 bit Bus speed : Auto Connecting... Device : Toshiba eMMC 032G74 Page size : 512 B Block size : 512 B Block count : 61071360 Size : 29.12 GB (29820.00 MB) --------------------------------------------------------------- CID Info CID : 110100303332473734009941B9C4720D Manufacturer ID : 0X11 Device/BGA : BGA (Discrete embedded) OEM/Application ID : 0X00 Product name : 032G74 Product revision : 0.0 Product serial number : (hex) 9941B9C4 Manufacturing date : 07/2015 --------------------------------------------------------------- CSD Info CSD : D02700320F5903FFFFFFFFE78640009B CSD structure : CSD version No. 1.2 SPEC version : 4.1, 4.2, 4.3, 4.4, 4.41, 4.5, 4.51, 5.0, 5.01, 5.1 Data read access time1: 15 ms TRAN speed : 26 MHz READ block length : 512 Bytes WP group enable : YES PERM_WRITE_PROTECT : NO TMP_WRITE_PROTECT : NO --------------------------------------------------------------- EXTCSD Info Revision 1.7 (for MMC v5.0, v5.01) Erase block size : 4096 Kbytes Boot1 size : 4096 Kbytes Boot2 size : 4096 Kbytes RPMB size : 4096 Kbytes Partition config : (0x00) 00000000 Boot partition enable : Device not boot enabled (default) (Bus width = 1Bit) Boot ACK : No boot acknowledge sent (default) Boot bus conditions : (0x00) 00000000 Boot bus width : x1 (sdr) or x4 (ddr) bus width in boot operation mode (default) Reset boot bus conditions : Reset bus width to x1, single data rate and backward compatible timings after boot operation (default) Boot mode : Use single data rate + backward compatible timings in boot operation (default) RST_n function : (0x01) RST_n signal is permanently enabled Partitioning support : Device supports partitioning features Enhanced attribute : Device can have enhanced technological features in partitions and user data area. Max enhanced data size: 15269888 Kbytes Partitions attribute : 0x0 Part setting completed: 0x0 GP partition 1 size : 0 b GP partition 2 size : 0 b GP partition 3 size : 0 b GP partition 4 size : 0 b Enhanced area size : (0x0) 0 b Enhanced area start : (0x0) 0 b ---------------------------------------------------------------Searching Android build info... Ok Disk/Image size : 47c00000 bytes Device sector size : 512 bytes Partition offset : 1458176 Number of sectors : 6291456 Device Manufacturer :google Device Platform :msm8992 Build ID :OPR4.170623.006 Display Build ID :OPR4.170623.006 Release ID :8.0.0 Device Model :Nexus 5X Device Name :bullhead Architecture ABI :arm64-v8a Architecture ABI List :arm64-v8a,armeabi-v7a,armeabi Build Description :bullhead-user 8.0.0 OPR4.170623.006 4286358 release-keys Backup EXT_CSD saved to file C:/Program Files (x86)/Medusa Pro Software/EXT_CSD Backups/032G74_05_06_2018_23_49_11.bin. Connect successful. --------------------------------------------------------------- SW: 1.6.0; FW: 1.23. P00: GPT (00000000, 00004000) 8 MB P01: modem (00004000, 0002B000) 86 MB P02: pmic (00030000, 00000400) 512 KB P03: sbl1 (00030400, 00000800) 1024 KB P04: tz (00030C00, 00000800) 1024 KB P05: sdi (00031400, 00000400) 512 KB P06: hyp (00031800, 00000400) 512 KB P07: rpm (00031C00, 00000400) 512 KB P08: aboot (00032000, 00001000) 2048 KB P09: sbl1bak (00033000, 00000800) 1024 KB P10: pmicbak (00033800, 00000400) 512 KB P11: tzbak (00033C00, 00000800) 1024 KB P12: hypbak (00034400, 00000400) 512 KB P13: rpmbak (00034800, 00000400) 512 KB P14: abootbak (00034C00, 00001000) 2048 KB P15: limits (00035C00, 00000400) 512 KB P16: config (00036000, 00000400) 512 KB P17: apdp (00036400, 00000400) 512 KB P18: msadp (00036800, 00000400) 512 KB P19: dpo (00036C00, 00000400) 512 KB P20: fsc (00037000, 00000400) 512 KB P21: ssd (00037400, 00000400) 512 KB P22: sec (00037800, 00000400) 512 KB P23: misc (00037C00, 00008000) 16 MB P24: persist (0003FC00, 00010000) 32 MB P25: modemst1 (0004FC00, 00000C00) 1536 KB P26: modemst2 (00050800, 00000C00) 1536 KB P27: fsg (00051400, 00000C00) 1536 KB P28: DDR (00052000, 00001000) 2048 KB P29: imgdata (00053000, 00001800) 3072 KB P30: metadata (00054800, 00008000) 16 MB P31: laf (0005C800, 00018000) 48 MB P32: keymaster (00074800, 00000400) 512 KB P33: cmnlib (00074C00, 00000400) 512 KB P34: keymasterbak (00075000, 00000400) 512 KB P35: cmnlibbak (00075400, 00000400) 512 KB P36: oem (00078000, 00020000) 64 MB P37: boot (00098000, 00010000) 32 MB P38: recovery (000A8000, 00010000) 32 MB P39: vendor (000B8000, 0007C000) 248 MB P40: cache (00134000, 00030000) 96 MB P41: system (00164000, 00600000) 3072 MB P42: persistent (00764000, 00000400) 512 KB P43: devinfo (00768000, 00000400) 512 KB P44: keystore (00768400, 00000400) 512 KB P45: userdata (0076C000, 032D1FDC) 25.41 GB P46: grow (03A3DFDC, 00000003) 1536 b Repairing from file "C:/Program Files (x86)/Medusa Pro Software/firmwareFolder/LG_H790_EMMC_016G72.srf". Write data verification is enabled. Writing GPT partition... Done. Writing modem partition... Done. Writing pmic partition... Done. Writing sbl1 partition... Done. Writing tz partition... Done. Writing sdi partition... Done. Writing hyp partition... Done. Writing rpm partition... Done. Writing aboot partition... Done. Writing limits partition... Done. Writing config partition... Done. Writing apdp partition... Done. Writing msadp partition... Done. Writing dpo partition... Done. Writing fsc partition... Done. Writing ssd partition... Done. Writing sec partition... Done. Writing misc partition... Done. Writing persist partition... Done. Writing modemst1 partition... Done. Writing modemst2 partition... Done. Writing fsg partition... Done. Writing DDR partition... Done. Writing imgdata partition... Done. Writing metadata partition... Done. Writing laf partition... Done. Writing keymaster partition... Done. Writing cmnlib partition... Done. Writing keymasterbak partition... Done. Writing cmnlibbak partition... Done. Writing oem partition... Done. Writing boot partition... Done. Writing recovery partition... Done. Writing persistent partition... Done. Writing devinfo partition... Done. Writing keystore partition... Done. Smart Repair is successfully complete. there is zip file emmc bin should i write to the phone ? please advice me Last edited by Medusa Box; 06-05-2018 at 14:07. |
06-05-2018, 14:07 | #2 (permalink) |
Product Supporter Join Date: Mar 2011 Location: Octopus-team
Member: 1538383 Status: Offline Sonork: 100.1587278 Thanks Meter: 3,395 | Hello Does the device goes into Download (Emergency) Mode after "Smart Repair" operation? If no, unpack full flash and try to write it. Also You can try to do "Factory Repair" using the latest available original firmware for this device model. |
